PSPICE-FOR-TI: PSPICE-FOR-TI: Too many devices are attempting to connect with the same access key.
Part Number: PSPICE-FOR-TI
I tried formatting a new computer and installing TI's pspice, similar to the other questions. But it says that there are many devices installed with the same access code and it can't be installed... Can you send me other installation programs or other access codes?
  • Hi Tae Wook,
    I'll have to have the old installs disabled. Once that's done, you'll be able to install a fresh version.
    I'll contact you here when that's done.
    David
  • Your old installs have been disabled. You may now install a fresh version of PSpice for TI.
    Please let me know if the library doesn't populate. This has been identified as a problem when English is not the default language and there is a work-around.
    The latest version includes ~1000 models for simple devices such as BJT, Diodes, MOSFETs.
    You may now import 1 model without a problem (it can have multiple instances) and you can plot 4 waveforms (4 active markers) if you import more than 1 model.
    David
