Part Number: TIDA-010054
I found the Dual Phase Shift PLECS simulation file but did not see the single phase shift control PLECS file. Where can I find It?
Thank you.
Thank you.
The modulation can be changed within the model. If the signal EPS_EN is 1, extended phase shift will be used, if EPE_EN is 0 then single phase shift will be used,
Andreas
Hi Andreas,
I have some confusion about the voltage control loop design. Can you please provide some information related to that?
Hi Sachith,
In the reference design we used a DF22 compensator to achieve a faster voltage loop.
The implementation is shown in the User's Guide of the Digital Control Library: https://www.ti.com/lit/ug/spruid3/spruid3.pdf
Please refer to Figure 3-14 on page 45.
Hope this helps.
Andreas
