PSPICE-FOR-TI: Pspice for TI
ERROR(ORCOMMN-12005): Unable to launch OrCAD PSpice TI. A valid License was not found at the <none> license server. Update the license server configuration to include OrCAD PSpice TI licenses.
facing this error after installation. Once it run correctly but on the second day it fails and show this error.
  • I have the same problem.  I installed PSpice on 12/10/25 and now on 12/11/25 I get the same license error.  There are posts from 4 years ago that solved the problem by unintalling and re-installing with the claim that this would be fixed on the next release.  Did that release happen or are we forced to start over with a fresh installlation?
  • I tried reinstallation multiple time but the error is same for everytime.
  • Hi y'all,
    The license is on your hard drive at %appdata%/\Cadence\VBL\TI_PSpice_231\license
    license.txt
    The fact that the program is looking elsewhere is the problem.
    When you did a re-install, did you use add/remove programs to remove and then reboot? The uninstall process removes more than just the program.
    If you didn't try that, please go ahead and give it a shot.
    Next thing to try will be to clear your registry folder:
    1. Close PSpice for TI
    2. Open registry editor and go to HKEY_CURRENT_USER\SOFTWARE\Orcad\CaptureTIPspice_Install\23.1.0
    3. Delete the 23.1.0 folder
    And finally, if that doesn't work, we'll need to collect some data to identify what's going on.
    To do that, we'll need to setup an environment variable:
    CDS_LIC_QA_TesT environment variable
    The CDS_LIC_QA_TesT environment variable is a testability code that is set on the client system running the Cadence tools. The variable is set for troubleshooting Licensing issues. CDS_LIC_QA_TesT must be set before the invocation of the Cadence tool. The value of this variable is any writable area on your system.
    Windows:
    Access the Windows button, search for edit environment variables for your account.
    New > CDS_LIC_QA_TesT = c:\cadence\qalog.txt
    After setting this variable, invoke the tool. If you get a Licensing error, send the qalog.txt file to Customer Support. The qalog.txt file can grow quite large over time. Hence, it is best to unset the variable when your problem is solved.
    Note: Do not set this variable in c:\ drive as you may not have write permission there and the file will not get created. Please set it either in c:\cadence or in a different drive like d:\ .
    David
  • I've also raised this issue with Cadence as there is another user having the same problem.
    David
  • Hi David,
    I have tried everything that you detial above and still have the same license problem.  I will send the qalog to Customer Support.
  • You can post it here. Insert->Image/Video/file
    I'll get it to cadnce in case there's anything to help them debug their issue.
    David
  • Here is the file:
    01/13/2025 08:47:11 (566770-29780): License Mode: bundleName is set to TI_PSpice_231
    01/13/2025 08:47:11 (566770-29780): Initialization started (23.02-a004)...
    01/13/2025 08:47:11 (566770-29780): FLEXnet version 11.16.4.0 build 252457
    01/13/2025 08:47:11 (566770-29780): Process ID 25392
    01/13/2025 08:47:11 (566770-29780): Creating a new job ...
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Get License File called with bundle TI_PSpice_231
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) VBL version: (23.02-s004)
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Licensing errors/warnings set in product_key flow
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Setting LastErrCode: 0
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Getting LastErrCode: 0
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) License file path stored in the registry is C:\Users\kcger\AppData\Roaming\Cadence\VBL\TI_PSpice_231\license\license.txt
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) cdsVbliGetLicenseFile returned 0
    01/13/2025 08:47:11 (566770-29780):   Configuration of license path is 'C:\Users\kcger\AppData\Roaming\Cadence\VBL\TI_PSpice_231\license\license.txt'.
    01/13/2025 08:47:11 (566770-29780):   Configuration of recheck interval minimum is 290.
    01/13/2025 08:47:11 (566770-29780):   Configuration of 2000000000 maximum retry calls.
    01/13/2025 08:47:11 (566770-29780):   Configuration of sleep time value of 0.
    01/13/2025 08:47:11 (566770-29780):   Configuration of display specification is '0:0'.
    01/13/2025 08:47:11 (566770-29780):   Licenses will be checked out using kcger@Laptop-Kevin(0:0).
    01/13/2025 08:47:11 (566770-29780):   (System spec would have been kcger@Laptop-Kevin(Laptop-Kevin) )
    01/13/2025 08:47:11 (566770-29780): Job creation completed with status 0 (time 0).
    01/13/2025 08:47:11 (566770-29780): Initialization completed with status 0 (time 0).
    01/13/2025 08:47:11 (566770-29780): License mode: Validate Trigger Interval is set to: 86401 sec
    01/13/2025 08:47:11 (566770-29780): License Mode: Starting ValidateLicenseThread
    01/13/2025 08:47:11 (566770-9468): License Mode: ValidateLicenseThread started
    01/13/2025 08:47:11 (566770-9468): License mode: calling cdsVblValidateLicense from thread...
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) Validate license called with bundle: TI_PSpice_231 and flex code: 1
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) Licensing errors/warnings set in product_key flow
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) Action code is 1
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) cdsVbliValidateLicense attempt 0/3
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) MFP version: (22.01-d007)
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) Get hw addresses called with upOnly=True
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) HW addresses:
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) Checking: mac=ff6572f638 addlen=6 type=53 status=2 len=448 index=9 flags=1c5 connType=1 tunType=0 name={6572F638-79FE-4B63-B829-F17A3EC71B43}
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) Skipping as not up
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) User has entitlement types: Commercial
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) Checking: mac=e86a640992f3 addlen=6 type=6 status=2 len=448 index=4 flags=1c5 connType=1 tunType=0 name={1965E383-FD2B-4E52-8DFA-9605EC76D853}
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) Setting LastErrCode: 0
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) Checking: mac=645d8672fceb addlen=6 type=71 status=2 len=448 index=20 flags=1c5 connType=1 tunType=0 name={D66B0A0F-97C0-4559-B4C2-A8A2DF83C0F9}
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) Checking: mac=665d8672fcea addlen=6 type=71 status=2 len=448 index=12 flags=1c5 connType=1 tunType=0 name={A5CD2C74-E097-4DB9-A1D0-489B86F458F4}
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) Checking: mac=645d8672fcea addlen=6 type=71 status=1 len=448 index=7 flags=1c5 connType=1 tunType=0 name={3BB87F8F-47E1-42FC-838B-42993B6B12DC}
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) Friendly name: Wi-Fi
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) Setting as primary
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) Checking: mac=645d8672fcee addlen=6 type=6 status=2 len=448 index=21 flags=1c5 connType=1 tunType=0 name={FF73527E-18C4-4637-AF7F-905CDF830896}
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) Checking: mac=0 addlen=0 type=24 status=1 len=448 index=1 flags=181 connType=1 tunType=0 name={2AB817F9-427A-11E8-ADD3-806E6F6E6963}
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) Skipping as lookup
    01/13/2025 08:47:11 (pid-25392-29780): (mfp) HW addresses end
    01/13/2025 08:47:11 (566770-29780): Api started: api=FeatureExists;feature=PSpice_TI;version=23.10000
    01/13/2025 08:47:11 (566770-29780): FeatureExists started ....
    01/13/2025 08:47:11 (566770-29780): Check-out started ....
    01/13/2025 08:47:11 (566770-29780): Testing only for the validity of feature PSpice_TI 23.100...
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) Error: Getting registry value size for a key has failed. Registry key name: server_configuration - error code: 2
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) Setting LastErrCode: -2071
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) Error: Failed to read storage entry. Entry key is: server_configuration
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) Setting LastErrCode: -2054
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) Updating error code status for bundle name: <TI_PSpice_231> with the value of: <-2071>
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) cdsVbliValidateLicense returned -2071
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) Mapping Vbl Internal Error code: (-2071) to Public Error Code: (-1)
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) Getting WarningErrorCode: 0
    01/13/2025 08:47:11 (pid-25392-9468): (vbl) cdsVblCheckForWarnings returned internal warning code: 0
    01/13/2025 08:47:11 (566770-9468): License mode: Sleeping for 86442 sec
    01/13/2025 08:47:11 (566770-29780):  License Mode: First checkout status:
    01/13/2025 08:47:11 (566770-29780):  License Mode checkout status with status:(-10)
    01/13/2025 08:47:11 (566770-29780):  License Mode: FlexNetErr Code:
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Validate license called with bundle: TI_PSpice_231 and flex code: -10
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Action code is 6
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) cdsVbliValidateLicense attempt 0/3
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Error: Getting registry value size for a key has failed. Registry key name: server_configuration - error code: 2
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Setting LastErrCode: -2071
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Error: Failed to read storage entry. Entry key is: server_configuration
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Setting LastErrCode: -2054
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Updating error code status for bundle name: <TI_PSpice_231> with the value of: <-2071>
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) cdsVbliValidateLicense returned -2071
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Mapping Vbl Internal Error code: (-2071) to Public Error Code: (-1)
    01/13/2025 08:47:11 (566770-29780):  License Mode: cdsVblValidateLicense status:
    01/13/2025 08:47:11 (566770-29780):  License Mode checkout status with status:(-1)
    01/13/2025 08:47:11 (566770-29780):  License Mode: Vbl Returned Last vblerror code
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Getting LastErrCode: -2071
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) cdsVblGetLastError returned internal error code: -2071
    01/13/2025 08:47:11 (566770-29780):  License Mode checkout status with status:(-2071)
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Last set CHWS error code -20 does not match with last set error code -2071
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) Getting LastChwsErrCode: -20
    01/13/2025 08:47:11 (pid-25392-29780): (vbl) cdsVblIsValidChwsError returned 0 and the last set Chws error code is: -20
    01/13/2025 08:47:11 (566770-29780): Validity test completed with status -10.
    01/13/2025 08:47:11 (566770-29780): Check-out completed with status -10 (time 0).
    01/13/2025 08:47:11 (566770-29780): FeatureExists of PSpice_TI completed with status -10 (time 0).
    01/13/2025 08:47:11 (566770-29780): Api started: api=FeatureExists;feature=PSpice_TI_Plus;version=23.10000
    01/13/2025 08:47:11 (566770-29780): Testing only for the validity of feature PSpice_TI_Plus 23.100...
    01/13/2025 08:47:11 (566770-29780): Validity test completed with status -5.
    01/13/2025 08:47:11 (566770-29780): Check-out completed with status -5 (time 0).
    01/13/2025 08:47:11 (566770-29780): FeatureExists of PSpice_TI_Plus completed with status -5 (time 0).
    01/13/2025 08:47:16 (566770-29780): License mode: signaling thread to stop
    01/13/2025 08:47:16 (566770-29780): License mode: waiting for thread to stop
    01/13/2025 08:47:16 (566770-9468): License mode: Thread woke up, passed: 5 sec, sleep left: 86437 sec
    01/13/2025 08:47:16 (566770-9468): License mode: Exiting thread gracefully due to Signal by lmExit...
    01/13/2025 08:47:16 (566770-9468): License mode: ValidateLicenseThread is stopping...
    01/13/2025 08:47:16 (566770-29780): License mode: thread stopping took 0 sec
    01/13/2025 08:47:16 (566770-29780): Exit started ....
    01/13/2025 08:47:16 (566770-29780): Exit completed with status 0 (time 0).
    I installed the latest version from TI few days ago. Worked fine for two days, and then few days ago started getting same error. Things I have tried that DID NOT work:
    - Un-installing, rebooting and reinstalling (Gets stuck at trying to download license file, fails and finishes). I tried changing internet connections as well. Nothing worked.
    - Clearing registry as David suggested
    I have generated the qalog.txt as asked, and is attached.
    01/14/2025 15:18:05 (210570-6100): License Mode: bundleName is set to TI_PSpice_231
    01/14/2025 15:18:05 (210570-6100): Initialization started (23.02-a004)...
    01/14/2025 15:18:05 (210570-6100): FLEXnet version 11.16.4.0 build 252457
    01/14/2025 15:18:05 (210570-6100): Process ID 15740
    01/14/2025 15:18:05 (210570-6100): Creating a new job ...
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Get License File called with bundle TI_PSpice_231
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) VBL version: (23.02-s004)
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Licensing errors/warnings set in product_key flow
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Setting LastErrCode: 0
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Getting LastErrCode: 0
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) File not found or unavailable
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Error while reading license file at C:\Users\STiwana\AppData\Roaming\Cadence\VBL\TI_PSpice_231\license\license.txt, error code: -2040
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) License file path stored in the registry is C:\Users\STiwana\AppData\Roaming\Cadence\VBL\TI_PSpice_231\license\license.txt
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Setting LastErrCode: -2038
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) cdsVbliGetLicenseFile returned -2038
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Mapping Vbl Internal Error code: (-2038) to Public Error Code: (-4)
    01/14/2025 15:18:05 (210570-6100):   Configuration of recheck interval minimum is 290.
    01/14/2025 15:18:05 (210570-6100):   Configuration of 2000000000 maximum retry calls.
    01/14/2025 15:18:05 (210570-6100):   Configuration of sleep time value of 0.
    01/14/2025 15:18:05 (210570-6100):   Configuration of display specification is '0:0'.
    01/14/2025 15:18:05 (210570-6100):   Licenses will be checked out using STiwana@MA1-PC021(0:0).
    01/14/2025 15:18:05 (210570-6100):   (System spec would have been STiwana@MA1-PC021(MA1-PC021) )
    01/14/2025 15:18:05 (210570-6100): Job creation completed with status 0 (time 0).
    01/14/2025 15:18:05 (210570-6100): Initialization completed with status 0 (time 0).
    01/14/2025 15:18:05 (210570-6100): License mode: Validate Trigger Interval is set to: 86401 sec
    01/14/2025 15:18:05 (210570-6100): License Mode: Starting ValidateLicenseThread
    01/14/2025 15:18:05 (210570-14316): License Mode: ValidateLicenseThread started
    01/14/2025 15:18:05 (210570-14316): License mode: calling cdsVblValidateLicense from thread...
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) Validate license called with bundle: TI_PSpice_231 and flex code: 1
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) Licensing errors/warnings set in product_key flow
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) Action code is 1
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) cdsVbliValidateLicense attempt 0/3
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) MFP version: (22.01-d007)
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) Get hw addresses called with upOnly=True
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) File not found or unavailable
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) Error while reading license file at C:\Users\STiwana\AppData\Roaming\Cadence\VBL\TI_PSpice_231\license\license.txt, error code: -2040
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) User has entitlement types: Commercial
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) Setting LastErrCode: 0
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) HW addresses:
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) Checking: mac=e86a64849cb6 addlen=6 type=6 status=2 len=448 index=12 flags=1c1 connType=1 tunType=0 name={77FE63AD-7742-4224-9D15-13DA2D882FD2}
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) Skipping as not up
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) Checking: mac=ac91a1fc7296 addlen=6 type=6 status=1 len=448 index=4 flags=1c5 connType=1 tunType=0 name={0908834D-F391-4D1D-85A0-3F0396F165C4}
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) Friendly name: Ethernet 6
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) Checking: mac=d43b047d6785 addlen=6 type=71 status=2 len=448 index=15 flags=1c5 connType=1 tunType=0 name={92C33AD1-D59A-4578-8915-E72ED300F41D}
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) Checking: mac=d63b047d6784 addlen=6 type=71 status=1 len=448 index=6 flags=1c1 connType=1 tunType=0 name={2B6ABDEB-5917-493A-B360-5554AE14F30B}
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) Friendly name: Local Area Connection* 2
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) Checking: mac=d43b047d6784 addlen=6 type=71 status=1 len=448 index=13 flags=1c5 connType=1 tunType=0 name={7EAC2686-633C-4D78-8932-A740D6B47C6F}
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) Friendly name: Wi-Fi
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) Setting as primary
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) Checking: mac=d43b047d6788 addlen=6 type=6 status=2 len=448 index=7 flags=1c5 connType=1 tunType=0 name={2B891770-90B4-433C-994C-46F2921FEA82}
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) Checking: mac=0 addlen=0 type=24 status=1 len=448 index=1 flags=181 connType=1 tunType=0 name={6333FC8E-8ECF-11E9-8AB0-806E6F6E6963}
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) Skipping as lookup
    01/14/2025 15:18:05 (pid-15740-6100): (mfp) HW addresses end
    01/14/2025 15:18:05 (210570-6100): Api started: api=FeatureExists;feature=PSpice_TI;version=23.10000
    01/14/2025 15:18:05 (210570-6100): FeatureExists started ....
    01/14/2025 15:18:05 (210570-6100): Check-out started ....
    01/14/2025 15:18:05 (210570-6100): Testing only for the validity of feature PSpice_TI 23.100...
    01/14/2025 15:18:05 (210570-6100):  License Mode: First checkout status:
    01/14/2025 15:18:05 (210570-6100):  License Mode checkout status with status:(-1)
    01/14/2025 15:18:05 (210570-6100):  License Mode: FlexNetErr Code:
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Validate license called with bundle: TI_PSpice_231 and flex code: -1
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Action code is 2
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) cdsVbliValidateLicense attempt 0/3
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) Error: Getting registry value size for a key has failed. Registry key name: server_configuration - error code: 2
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) Setting LastErrCode: -2071
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) Error: Failed to read storage entry. Entry key is: server_configuration
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) Setting LastErrCode: -2054
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) Updating error code status for bundle name: <TI_PSpice_231> with the value of: <-2071>
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) cdsVbliValidateLicense returned -2071
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) Mapping Vbl Internal Error code: (-2071) to Public Error Code: (-1)
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) Getting WarningErrorCode: 0
    01/14/2025 15:18:05 (pid-15740-14316): (vbl) cdsVblCheckForWarnings returned internal warning code: 0
    01/14/2025 15:18:05 (210570-14316): License mode: Sleeping for 86442 sec
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Error: Getting registry value size for a key has failed. Registry key name: server_configuration - error code: 2
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Setting LastErrCode: -2071
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Error: Getting registry value size for a key has failed. Registry key name: RegistryUpdateData - error code: 2
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Error: Failed to read storage entry. Entry key is: server_configuration
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Setting LastErrCode: -2054
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Updating error code status for bundle name: <TI_PSpice_231> with the value of: <-2071>
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) cdsVbliValidateLicense returned -2071
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Mapping Vbl Internal Error code: (-2071) to Public Error Code: (-1)
    01/14/2025 15:18:05 (210570-6100):  License Mode: cdsVblValidateLicense status:
    01/14/2025 15:18:05 (210570-6100):  License Mode: Vbl Returned Last vblerror code
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) Getting LastErrCode: -2071
    01/14/2025 15:18:05 (pid-15740-6100): (vbl) cdsVblGetLastError returned internal error code: -2071
    01/14/2025 15:18:05 (210570-6100):  License Mode checkout status with status:(-2071)
    01/14/2025 15:18:05 (210570-6100): Validity test completed with status -1.
    01/14/2025 15:18:05 (210570-6100): Check-out completed with status -1 (time 0).
    01/14/2025 15:18:05 (210570-6100): FeatureExists of PSpice_TI completed with status -1 (time 0).
    01/14/2025 15:18:05 (210570-6100): Api started: api=FeatureExists;feature=PSpice_TI_Plus;version=23.10000
    01/14/2025 15:18:05 (210570-6100): Testing only for the validity of feature PSpice_TI_Plus 23.100...
    01/14/2025 15:18:05 (210570-6100): FeatureExists of PSpice_TI_Plus completed with status -1 (time 0).
    01/14/2025 15:18:08 (210570-6100): License mode: signaling thread to stop
    01/14/2025 15:18:08 (210570-6100): License mode: waiting for thread to stop
    ec, sleep left: 86439 sec
    01/14/2025 15:18:08 (210570-14316): License mode: Exiting thread gracefully due to Signal by lmExit...
    01/14/2025 15:18:08 (210570-14316): License mode: ValidateLicenseThread is stopping...
    01/14/2025 15:18:08 (210570-6100): License mode: thread stopping took 0 sec
    01/14/2025 15:18:08 (210570-6100): Exit started ....
    01/14/2025 15:18:08 (210570-6100): Exit completed with status 0 (time 0).
    Saad
  • Thank you, Saad.
    This is VERY helpful. I've passed your comments and log file on to Cadence. Your reporting and attempts to debug were insighful and will help Cadence identify the source of the error.
    If it were just Jan 1, 2025, then I'd guess a problem with the year. But it all started yesterday, 1/13/25. Not sure what's special about that date.
    It's not my birthday or anything.
    David
  • Hi David,
    I would like to report that I just tried installing PSpice for TI again, and this time it installed successfully (I had un-installed it yesterday), and is running successfully as well. Fingers crossed.
    Looks like the issue on Cadence side maybe resolved now. Others may want to try again as well.
    Saad Tiwana
  • Hi Saad,
    That good news, maybe.
    I just got a ticket 2 hours ago (7 hours after your post) that is reporting this problem.
    Hopefully Ashgar and Kevin see this and try again.
    David
  • Hello David, Saad,
    I just re-installed PSpice and it seems to be running properly.  Hopefully it will work for more than one day this time.
    Kevin
  • Hi Kevin,
    I heard back from Cadence. They need some more data for debug. Can you help out?
    Here's what they said:
    Can you please ask user to uninstall the tool and re-run the installer with CDS_LIC_QA_TesT variable in place.
    Currently the QA logs are from the tool launch not from the installation.
    We need to figure out why during installation the license file does not get downloaded.
    David
  • One user has had success installing in admin mode.
    Please uninstall using add/remove program. Then re-install in admin mode.
    Let me know if that doesn't work.
    If you've setup the environment variable and it doesn't work. Please attach the qalog.txt here.
    If it does work, please remove the environment variable as it will continue to collect data and get very large over time.
    David
  • Hi Kevin,
    Multiple users have reported success installing in admin mode. Maybe something was squirrely with the server that ;provides the licenses.
    Anyway, that's apparently been fixed.
    Closing this, but please let me know if you continue to encounter problems.
    David
