Part Number: PSPICE-FOR-TI
I get license server error when running the application
Please reboot your PC and try again and create a debug file and share it with us if you still have trouble:
thanks,
JC
08/01/2025 13:46:57 (214170-5724): License Mode: bundleName is set to TI_PSpice_231
08/01/2025 13:46:57 (214170-5724): Initialization started (23.02-a004)...
08/01/2025 13:46:57 (214170-5724): FLEXnet version 11.16.4.0 build 252457
08/01/2025 13:46:57 (214170-5724): Process ID 20232
08/01/2025 13:46:57 (214170-5724): Creating a new job ...
08/01/2025 13:46:57 (pid-20232-5724): (vbl) Get License File called with bundle TI_PSpice_231
08/01/2025 13:46:57 (pid-20232-5724): (vbl) VBL version: (23.02-s004)
08/01/2025 13:46:57 (pid-20232-5724): (vbl) Licensing errors/warnings set in product_key flow
08/01/2025 13:46:57 (pid-20232-5724): (vbl) Setting LastErrCode: 0
08/01/2025 13:46:57 (pid-20232-5724): (vbl) Getting LastErrCode: 0
08/01/2025 13:46:57 (pid-20232-5724): (vbl) Error: Getting registry value size for a key has failed. Registry key name: Vlt - error code: 2
08/01/2025 13:46:57 (pid-20232-5724): (vbl) Setting LastErrCode: -2089
08/01/2025 13:46:57 (pid-20232-5724): (vbl) License configuration data found corrupted while retrieving value for LicFilePath
08/01/2025 13:46:57 (pid-20232-5724): (vbl) cdsVbliGetLicenseFile returned 0
08/01/2025 13:46:57 (214170-5724): Configuration of license path is 'C:\Users\aafsari\AppData\Roaming\Cadence\VBL\TI_PSpice_231\license\license.txt'.
08/01/2025 13:46:57 (214170-5724): Configuration of recheck interval minimum is 290.
08/01/2025 13:46:57 (214170-5724): Configuration of 2000000000 maximum retry calls.
08/01/2025 13:46:57 (214170-5724): Configuration of sleep time value of 0.
08/01/2025 13:46:57 (214170-5724): Configuration of display specification is '0:0'.
08/01/2025 13:46:57 (214170-5724): Licenses will be checked out using aafsari@6N2K6X3-PC(0:0).
08/01/2025 13:46:57 (214170-5724): (System spec would have been aafsari@6N2K6X3-PC(6N2K6X3-PC) )
08/01/2025 13:46:57 (214170-5724): Job creation completed with status 0 (time 0).
08/01/2025 13:46:57 (214170-5724): Initialization completed with status 0 (time 0).
08/01/2025 13:46:57 (214170-5724): License mode: Validate Trigger Interval is set to: 86401 sec
08/01/2025 13:46:57 (214170-5724): License Mode: Starting ValidateLicenseThread
08/01/2025 13:46:57 (214170-20280): License Mode: ValidateLicenseThread started
08/01/2025 13:46:57 (214170-20280): License mode: calling cdsVblValidateLicense from thread...
08/01/2025 13:46:57 (pid-20232-20280): (vbl) Validate license called with bundle: TI_PSpice_231 and flex code: 1
08/01/2025 13:46:57 (pid-20232-20280): (vbl) Licensing errors/warnings set in product_key flow
08/01/2025 13:46:57 (pid-20232-20280): (vbl) Action code is 1
08/01/2025 13:46:57 (pid-20232-20280): (vbl) cdsVbliValidateLicense attempt 0/3
08/01/2025 13:46:57 (pid-20232-20280): (vbl) Error: Getting registry value size for a key has failed. Registry key name: Vlt - error code: 2
08/01/2025 13:46:57 (pid-20232-20280): (vbl) Setting LastErrCode: -2089
08/01/2025 13:46:57 (pid-20232-20280): (vbl) License configuration data found corrupted while retrieving value for user_configuration
08/01/2025 13:46:57 (pid-20232-20280): (vbl) Error: VBL configuration data not found in registry
08/01/2025 13:46:57 (pid-20232-20280): (vbl) Updating error code status for bundle name: <TI_PSpice_231> with the value of: <-2089>
08/01/2025 13:46:57 (pid-20232-20280): (vbl) cdsVbliValidateLicense returned -2089
08/01/2025 13:46:57 (pid-20232-20280): (vbl) Mapping Vbl Internal Error code: (-2089) to Public Error Code: (-1)
08/01/2025 13:46:57 (pid-20232-20280): (vbl) Getting WarningErrorCode: 0
08/01/2025 13:46:57 (pid-20232-20280): (vbl) cdsVblCheckForWarnings returned internal warning code: 0
08/01/2025 13:46:57 (214170-20280): License mode: Sleeping for 86442 sec
08/01/2025 13:46:57 (pid-20232-5724): (mfp) MFP version: (22.01-d007)
08/01/2025 13:46:57 (pid-20232-5724): (mfp) Get hw addresses called with upOnly=True
08/01/2025 13:46:57 (pid-20232-5724): (mfp) HW addresses:
08/01/2025 13:46:57 (pid-20232-5724): (mfp) Checking: mac=c45ab1e41fbb addlen=6 type=6 status=1 len=448 index=7 flags=1c5 connType=1 tunType=0 name={6E929862-E66D-4F3E-909B-10F70A9132A2}
08/01/2025 13:46:57 (pid-20232-5724): (mfp) Friendly name: vEthernet (obsdSwitch)
08/01/2025 13:46:57 (pid-20232-5724): (mfp) Checking: mac=0 addlen=0 type=24 status=1 len=448 index=1 flags=181 connType=1 tunType=0 name={9B2A53A5-1AA0-11EE-AF89-806E6F6E6963}
08/01/2025 13:46:57 (pid-20232-5724): (mfp) Skipping as lookup
08/01/2025 13:46:57 (pid-20232-5724): (mfp) Checking: mac=155d625f00 addlen=6 type=6 status=1 len=448 index=12 flags=1c0 connType=1 tunType=0 name={44010211-19D0-4239-821E-D272A54B1A4D}
08/01/2025 13:46:57 (pid-20232-5724): (mfp) Friendly name: vEthernet (Default Switch)
08/01/2025 13:46:57 (pid-20232-5724): (mfp) HW addresses end
08/01/2025 13:46:57 (pid-20232-5724): (mfp) No primary adapter was found, setting as first non-skipped one
08/01/2025 13:46:57 (214170-5724): Api started: api=FeatureExists;feature=PSpice_TI;version=23.10000
08/01/2025 13:46:57 (214170-5724): FeatureExists started ....
08/01/2025 13:46:57 (214170-5724): Check-out started ....
08/01/2025 13:46:57 (214170-5724): Testing only for the validity of feature PSpice_TI 23.100...
08/01/2025 13:46:57 (214170-5724): Validity test completed with status -5.
08/01/2025 13:46:57 (214170-5724): Check-out completed with status -5 (time 0).
08/01/2025 13:46:57 (214170-5724): FeatureExists of PSpice_TI completed with status -5 (time 0).
08/01/2025 13:46:57 (214170-5724): Api started: api=FeatureExists;feature=PSpice_TI_Plus;version=23.10000
08/01/2025 13:46:57 (214170-5724): Testing only for the validity of feature PSpice_TI_Plus 23.100...
08/01/2025 13:46:57 (214170-5724): FeatureExists of PSpice_TI_Plus completed with status -5 (time 0).
08/01/2025 13:47:01 (214170-5724): License mode: signaling thread to stop
08/01/2025 13:47:01 (214170-5724): License mode: waiting for thread to stop
ec, sleep left: 86438 sec
08/01/2025 13:47:01 (214170-20280): License mode: Exiting thread gracefully due to Signal by lmExit...
08/01/2025 13:47:01 (214170-20280): License mode: ValidateLicenseThread is stopping...
08/01/2025 13:47:01 (214170-5724): License mode: thread stopping took 0 sec
08/01/2025 13:47:01 (214170-5724): Exit started ....
08/01/2025 13:47:01 (214170-5724): Exit completed with status 0 (time 0).
Ali
Hi Ali,
The license outage is fixed. Please check if it is still broken for you.
JC
Hi JC,
I am still getting error. Note that The error stopped on my laptop but still shows on my desktop.
Ali
08/05/2025 10:00:57 (862800-15868): License Mode: bundleName is set to TI_PSpice_231
08/05/2025 10:00:57 (862800-15868): Initialization started (23.02-a004)...
08/05/2025 10:00:57 (862800-15868): FLEXnet version 11.16.4.0 build 252457
08/05/2025 10:00:57 (862800-15868): Process ID 4484
08/05/2025 10:00:57 (862800-15868): Creating a new job ...
08/05/2025 10:00:57 (pid-4484-15868): (vbl) Get License File called with bundle TI_PSpice_231
08/05/2025 10:00:57 (pid-4484-15868): (vbl) VBL version: (23.02-s004)
08/05/2025 10:00:57 (pid-4484-15868): (vbl) Licensing errors/warnings set in product_key flow
08/05/2025 10:00:57 (pid-4484-15868): (vbl) Setting LastErrCode: 0
08/05/2025 10:00:57 (pid-4484-15868): (vbl) Getting LastErrCode: 0
08/05/2025 10:00:57 (pid-4484-15868): (vbl) Error: Getting registry value size for a key has failed. Registry key name: Vlt - error code: 2
08/05/2025 10:00:57 (pid-4484-15868): (vbl) Setting LastErrCode: -2089
08/05/2025 10:00:57 (pid-4484-15868): (vbl) License configuration data found corrupted while retrieving value for LicFilePath
08/05/2025 10:00:57 (pid-4484-15868): (vbl) cdsVbliGetLicenseFile returned 0
08/05/2025 10:00:57 (862800-15868): Configuration of license path is 'C:\Users\aafsari\AppData\Roaming\Cadence\VBL\TI_PSpice_231\license\license.txt'.
08/05/2025 10:00:57 (862800-15868): Configuration of recheck interval minimum is 290.
08/05/2025 10:00:57 (862800-15868): Configuration of 2000000000 maximum retry calls.
08/05/2025 10:00:57 (862800-15868): Configuration of sleep time value of 0.
08/05/2025 10:00:57 (862800-15868): Configuration of display specification is '0:0'.
08/05/2025 10:00:57 (862800-15868): Licenses will be checked out using aafsari@6N2K6X3-PC(0:0).
08/05/2025 10:00:57 (862800-15868): (System spec would have been aafsari@6N2K6X3-PC(6N2K6X3-PC) )
08/05/2025 10:00:57 (862800-15868): Job creation completed with status 0 (time 0).
08/05/2025 10:00:57 (862800-15868): Initialization completed with status 0 (time 0).
08/05/2025 10:00:57 (862800-15868): License mode: Validate Trigger Interval is set to: 86401 sec
08/05/2025 10:00:57 (862800-15868): License Mode: Starting ValidateLicenseThread
08/05/2025 10:00:57 (862800-23308): License Mode: ValidateLicenseThread started
08/05/2025 10:00:57 (862800-23308): License mode: calling cdsVblValidateLicense from thread...
08/05/2025 10:00:57 (pid-4484-23308): (vbl) Validate license called with bundle: TI_PSpice_231 and flex code: 1
08/05/2025 10:00:57 (pid-4484-23308): (vbl) Licensing errors/warnings set in product_key flow
08/05/2025 10:00:57 (pid-4484-23308): (vbl) Action code is 1
08/05/2025 10:00:57 (pid-4484-23308): (vbl) cdsVbliValidateLicense attempt 0/3
08/05/2025 10:00:57 (pid-4484-23308): (vbl) Error: Getting registry value size for a key has failed. Registry key name: Vlt - error code: 2
08/05/2025 10:00:57 (pid-4484-23308): (vbl) Setting LastErrCode: -2089
08/05/2025 10:00:57 (pid-4484-23308): (vbl) License configuration data found corrupted while retrieving value for user_configuration
08/05/2025 10:00:57 (pid-4484-23308): (vbl) Error: VBL configuration data not found in registry
08/05/2025 10:00:57 (pid-4484-23308): (vbl) Updating error code status for bundle name: <TI_PSpice_231> with the value of: <-2089>
08/05/2025 10:00:57 (pid-4484-15868): (mfp) Get hw addresses called with upOnly=True
08/05/2025 10:00:57 (pid-4484-23308): (vbl) cdsVbliValidateLicense returned -2089
08/05/2025 10:00:57 (pid-4484-23308): (vbl) Mapping Vbl Internal Error code: (-2089) to Public Error Code: (-1)
08/05/2025 10:00:57 (pid-4484-23308): (vbl) Getting WarningErrorCode: 0
08/05/2025 10:00:57 (pid-4484-23308): (vbl) cdsVblCheckForWarnings returned internal warning code: 0
08/05/2025 10:00:57 (862800-23308): License mode: Sleeping for 86442 sec
08/05/2025 10:00:57 (pid-4484-15868): (mfp) HW addresses:
08/05/2025 10:00:57 (pid-4484-15868): (mfp) Checking: mac=c45ab1e41fbb addlen=6 type=6 status=1 len=448 index=7 flags=1c5 connType=1 tunType=0 name={6E929862-E66D-4F3E-909B-10F70A9132A2}
08/05/2025 10:00:57 (pid-4484-15868): (mfp) Friendly name: vEthernet (obsdSwitch)
08/05/2025 10:00:57 (pid-4484-15868): (mfp) Checking: mac=0 addlen=0 type=24 status=1 len=448 index=1 flags=181 connType=1 tunType=0 name={9B2A53A5-1AA0-11EE-AF89-806E6F6E6963}
08/05/2025 10:00:57 (pid-4484-15868): (mfp) Skipping as lookup
08/05/2025 10:00:57 (pid-4484-15868): (mfp) Checking: mac=155d625f00 addlen=6 type=6 status=1 len=448 index=12 flags=1c0 connType=1 tunType=0 name={44010211-19D0-4239-821E-D272A54B1A4D}
08/05/2025 10:00:57 (pid-4484-15868): (mfp) Friendly name: vEthernet (Default Switch)
08/05/2025 10:00:57 (pid-4484-15868): (mfp) HW addresses end
08/05/2025 10:00:57 (pid-4484-15868): (mfp) No primary adapter was found, setting as first non-skipped one
08/05/2025 10:00:57 (862800-15868): Api started: api=FeatureExists;feature=PSpice_TI;version=23.10000
08/05/2025 10:00:57 (862800-15868): FeatureExists started ....
08/05/2025 10:00:57 (862800-15868): Check-out started ....
08/05/2025 10:00:57 (862800-15868): Testing only for the validity of feature PSpice_TI 23.100...
08/05/2025 10:00:57 (862800-15868): Validity test completed with status -5.
08/05/2025 10:00:57 (862800-15868): Check-out completed with status -5 (time 0).
08/05/2025 10:00:57 (862800-15868): FeatureExists of PSpice_TI completed with status -5 (time 0).
08/05/2025 10:00:57 (862800-15868): Api started: api=FeatureExists;feature=PSpice_TI_Plus;version=23.10000
08/05/2025 10:00:57 (862800-15868): Testing only for the validity of feature PSpice_TI_Plus 23.100...
08/05/2025 10:00:57 (862800-15868): FeatureExists of PSpice_TI_Plus completed with status -5 (time 0).
08/05/2025 10:00:59 (862800-15868): License mode: signaling thread to stop
08/05/2025 10:00:59 (862800-15868): License mode: waiting for thread to stop
08/05/2025 10:00:59 (862800-23308): License mode: Thread woke up, passed: 2 sec, sleep left: 86440 sec
08/05/2025 10:00:59 (862800-23308): License mode: Exiting thread gracefully due to Signal by lmExit...
08/05/2025 10:00:59 (862800-23308): License mode: ValidateLicenseThread is stopping...
08/05/2025 10:00:59 (862800-15868): License mode: thread stopping took 0 sec
08/05/2025 10:00:59 (862800-15868): Exit started ....
08/05/2025 10:00:59 (862800-15868): Exit completed with status 0 (time 0).
08/05/2025 10:02:48 (254860-10776): License Mode: bundleName is set to TI_PSpice_231
08/05/2025 10:02:48 (254860-10776): Initialization started (23.02-a004)...
08/05/2025 10:02:48 (254860-10776): FLEXnet version 11.16.4.0 build 252457
08/05/2025 10:02:48 (254860-10776): Process ID 20980
08/05/2025 10:02:48 (254860-10776): Creating a new job ...
08/05/2025 10:02:48 (pid-20980-10776): (vbl) Get License File called with bundle TI_PSpice_231
08/05/2025 10:02:48 (pid-20980-10776): (vbl) VBL version: (23.02-s004)
08/05/2025 10:02:48 (pid-20980-10776): (vbl) Licensing errors/warnings set in product_key flow
08/05/2025 10:02:48 (pid-20980-10776): (vbl) Setting LastErrCode: 0
08/05/2025 10:02:48 (pid-20980-10776): (vbl) Getting LastErrCode: 0
08/05/2025 10:02:48 (pid-20980-10776): (vbl) Error: Getting registry value size for a key has failed. Registry key name: Vlt - error code: 2
08/05/2025 10:02:48 (pid-20980-10776): (vbl) Setting LastErrCode: -2089
08/05/2025 10:02:48 (pid-20980-10776): (vbl) License configuration data found corrupted while retrieving value for LicFilePath
08/05/2025 10:02:48 (pid-20980-10776): (vbl) cdsVbliGetLicenseFile returned 0
08/05/2025 10:02:48 (254860-10776): Configuration of license path is 'C:\Users\aafsari\AppData\Roaming\Cadence\VBL\TI_PSpice_231\license\license.txt'.
08/05/2025 10:02:48 (254860-10776): Configuration of recheck interval minimum is 290.
08/05/2025 10:02:48 (254860-10776): Configuration of 2000000000 maximum retry calls.
08/05/2025 10:02:48 (254860-10776): Configuration of sleep time value of 0.
08/05/2025 10:02:48 (254860-10776): Configuration of display specification is '0:0'.
08/05/2025 10:02:48 (254860-10776): Licenses will be checked out using aafsari@6N2K6X3-PC(0:0).
08/05/2025 10:02:48 (254860-10776): (System spec would have been aafsari@6N2K6X3-PC(6N2K6X3-PC) )
08/05/2025 10:02:48 (254860-10776): Job creation completed with status 0 (time 0).
08/05/2025 10:02:48 (254860-10776): Initialization completed with status 0 (time 0).
08/05/2025 10:02:48 (254860-10776): License mode: Validate Trigger Interval is set to: 86401 sec
08/05/2025 10:02:48 (254860-10776): License Mode: Starting ValidateLicenseThread
08/05/2025 10:02:48 (254860-17876): License Mode: ValidateLicenseThread started
08/05/2025 10:02:48 (254860-17876): License mode: calling cdsVblValidateLicense from thread...
08/05/2025 10:02:48 (pid-20980-17876): (vbl) Validate license called with bundle: TI_PSpice_231 and flex code: 1
08/05/2025 10:02:48 (pid-20980-17876): (vbl) Licensing errors/warnings set in product_key flow
08/05/2025 10:02:48 (pid-20980-17876): (vbl) Action code is 1
08/05/2025 10:02:48 (pid-20980-17876): (vbl) cdsVbliValidateLicense attempt 0/3
08/05/2025 10:02:48 (pid-20980-17876): (vbl) Error: Getting registry value size for a key has failed. Registry key name: Vlt - error code: 2
08/05/2025 10:02:48 (pid-20980-17876): (vbl) Setting LastErrCode: -2089
08/05/2025 10:02:48 (pid-20980-17876): (vbl) License configuration data found corrupted while retrieving value for user_configuration
08/05/2025 10:02:48 (pid-20980-17876): (vbl) Error: VBL configuration data not found in registry
08/05/2025 10:02:48 (pid-20980-17876): (vbl) Updating error code status for bundle name: <TI_PSpice_231> with the value of: <-2089>
08/05/2025 10:02:48 (pid-20980-17876): (vbl) cdsVbliValidateLicense returned -2089
08/05/2025 10:02:48 (pid-20980-17876): (vbl) Mapping Vbl Internal Error code: (-2089) to Public Error Code: (-1)
08/05/2025 10:02:48 (pid-20980-17876): (vbl) Getting WarningErrorCode: 0
08/05/2025 10:02:48 (pid-20980-17876): (vbl) cdsVblCheckForWarnings returned internal warning code: 0
08/05/2025 10:02:48 (pid-20980-10776): (mfp) MFP version: (22.01-d007)
08/05/2025 10:02:48 (254860-17876): License mode: Sleeping for 86442 sec
08/05/2025 10:02:48 (pid-20980-10776): (mfp) Get hw addresses called with upOnly=True
08/05/2025 10:02:48 (pid-20980-10776): (mfp) HW addresses:
08/05/2025 10:02:48 (pid-20980-10776): (mfp) Checking: mac=c45ab1e41fbb addlen=6 type=6 status=1 len=448 index=7 flags=1c5 connType=1 tunType=0 name={6E929862-E66D-4F3E-909B-10F70A9132A2}
08/05/2025 10:02:48 (pid-20980-10776): (mfp) Friendly name: vEthernet (obsdSwitch)
08/05/2025 10:02:48 (pid-20980-10776): (mfp) Checking: mac=0 addlen=0 type=24 status=1 len=448 index=1 flags=181 connType=1 tunType=0 name={9B2A53A5-1AA0-11EE-AF89-806E6F6E6963}
08/05/2025 10:02:48 (pid-20980-10776): (mfp) Skipping as lookup
08/05/2025 10:02:48 (pid-20980-10776): (mfp) Checking: mac=155d625f00 addlen=6 type=6 status=1 len=448 index=12 flags=1c0 connType=1 tunType=0 name={44010211-19D0-4239-821E-D272A54B1A4D}
08/05/2025 10:02:48 (pid-20980-10776): (mfp) Friendly name: vEthernet (Default Switch)
08/05/2025 10:02:48 (pid-20980-10776): (mfp) HW addresses end
08/05/2025 10:02:48 (pid-20980-10776): (mfp) No primary adapter was found, setting as first non-skipped one
08/05/2025 10:02:48 (254860-10776): Api started: api=FeatureExists;feature=PSpice_TI;version=23.10000
08/05/2025 10:02:48 (254860-10776): FeatureExists started ....
08/05/2025 10:02:48 (254860-10776): Check-out started ....
08/05/2025 10:02:48 (254860-10776): Testing only for the validity of feature PSpice_TI 23.100...
08/05/2025 10:02:48 (254860-10776): Validity test completed with status -5.
08/05/2025 10:02:48 (254860-10776): Check-out completed with status -5 (time 0).
08/05/2025 10:02:48 (254860-10776): FeatureExists of PSpice_TI completed with status -5 (time 0).
08/05/2025 10:02:48 (254860-10776): Api started: api=FeatureExists;feature=PSpice_TI_Plus;version=23.10000
08/05/2025 10:02:48 (254860-10776): Testing only for the validity of feature PSpice_TI_Plus 23.100...
08/05/2025 10:02:48 (254860-10776): FeatureExists of PSpice_TI_Plus completed with status -5 (time 0).
08/05/2025 10:02:50 (254860-10776): License mode: signaling thread to stop
08/05/2025 10:02:50 (254860-10776): License mode: waiting for thread to stop
08/05/2025 10:02:50 (254860-17876): License mode: Thread woke up, passed: 2 sec, sleep left: 86440 sec
08/05/2025 10:02:50 (254860-17876): License mode: Exiting thread gracefully due to Signal by lmExit...
08/05/2025 10:02:50 (254860-17876): License mode: ValidateLicenseThread is stopping...
08/05/2025 10:02:50 (254860-10776): License mode: thread stopping took 0 sec
08/05/2025 10:02:50 (254860-10776): Exit started ....
08/05/2025 10:02:50 (254860-10776): Exit completed with status 0 (time 0).
Hi Ali,
The error message is from 4 days ago. Is the problem current?
-JC
Hi Ali,
Thanks.
Not sure what the issue is with the registry. Please reboot and try again. If that does not work, uninstall, reboot, delete the log file, run the installer (make sure you have the latest installer) as the administrator and try again.
Latest installer:
JC
