Other Parts Discussed in Thread: CC2640R2L, CC2640R2F
Parça Numarası: CC2640R2L
CC2640R2L ,
I can't connect with j link. Necessary pin connect has been made.
thanks
Could you please edit your first message and translate it in English? That way a TI engineer will manage to pick this thread and answer it tomorrow - today is national holiday in the US.
If it helps, the CC2640R2 devices are set to communicate through cJTAG. You can also see this page https://wiki.segger.com/LAUNCHXL_CC2640R2 and this thread.
Was YiKai's suggestion of connecting TDI and TDO helpful? Did you find the recourses posted by Clement earlier insightful? Let us know if the issue persists.
Jan
I have no problem to use jlink connecting to LAUNCHXL-CC2640R2F so I suggest you to check your jtag connection thoroughly again.
You are connecting to CC2640R2F with j link. Did I get right?
So which version are you using? Is there a jlink project for CC2640R2L?
Different from CC2640R2L / R2F
Best Regards
Yes, I connect jlink to CC2640R2F. Basically, jTag interface of CC2640R2L and Cc2640R2F are the same.
Looking at your earlier screenshots, it seems no data is being read (IDCODE is all 0s). Do you know if the JTAG on this board is already locked? If it is, then that may be the reason for why you are not able to read everything. Another possible reason may be bad connections or wiring as YiKai had mentioned. I would recommend ensuring the wiring is as short as possibly and ensuring there is continuity between the pad and the wire.
Jan
I haven't been able to confirm yet.
I ordered this from Texas. I will try when it comes
Best Regards
If the JTAG is locked, then depending on how this was done it may be possible to completely reset and erase the flash of the device by performing a mass erase. This will erase all of the contents of the device, but may unlock the JTAG.
If you have ordered a LAUNCHXL-CC2640R2, then you should not have any issues with the JTAG out of the box.
Jan
We are glad to hear! Let us know the results of the test and if there are any issues, then let us know and we will get to the bottom of it together.
Jan
