Part Number: CC2642R
A customer found that a file under C:\Users\<username>\AppData\Local\Temp takes ~5k of memory in the map file generated by simple_peripheral_CC26x2R1_LAUNCHXL_tirtos_ccs:
I did a little research following this link and found this file can be opened by armofd.exe, it show information as below in armofd:
Would you please help explain what is this file and why it takes memory of CC2642? Is it possible to stop this file to be generated in order to save the memory of the device?
Please find the temp file and the map file as attached.
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/538/_7B00_50B4475C_2D00_2253_2D00_46D1_2D00_A8FA_2D00_D931DA281D52_7D00_
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/538/simple_5F00_peripheral_5F00_CC26X2R1_5F00_LAUNCHXL_5F00_tirtos_5F00_ccs.map
Shuyang
