Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
CC2340R5: CC2340R5 PER test harmonic issue
Part Number: CC2340R5
Hi Ti,
I have two question about CC2340R5 RF performance
1. I set output power level form 0dBm to 8dBm then check power. I find there is a big difference power level at 2~5 dBm. Is this normal? Because the max delta power is -0.32dB, I would use 0.82dB as the standard.
2. I find there is an hormonic tone when I use HCI_LE_EnhancedReceiverTest command. Is this normal?
Thanks.
