Part Number: SIMPLELINK-LOWPOWER-SDK
Just to let you know, I was trying to build simplelink-lowpower-f2-sdk from GitHub on linux but was getting the following error:
error: instruction requires: fp registers
I solved the problem by using an older version of cmake (3.22.1)
There is some incompatibility with newer versions of cmake. I am not sure in which version the problem was introduced, but I was trying to user cmake-3.29.3 and there is another post in the forum from someone with the same problem using CMake 3.27.4.
