Part Number: CC2340R5
We are using the LFOSC on the CC2340R53 as a source for the LFCLK RTC. After reading some documentation and reading this other forum post (https://e2e.ti.com/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/1309385/cc2340r5-improve-accuracy-of-lfclk-derived-rtc-when-using-lfosc-as-source), we were wondering if there was a reason that the referenced solution seems not to have been implemented yet for improving accuracy.
In regards to the above footnote, in the other forum post, it was noted that "For technical reasons it was found that improving the accuracy of the LFCLK-derived RTC, and thus the footnote will be removed from the datasheet.". This footnote still exists in the datasheet. The forum post also mentioned a "workaround" that is planned. Was this ever implemented, or will it be? If not, is there a particular reason for this?
I see that calibration does exist on other devices using the AUX_TDC driver, but according to the following forum post, the hardware exists on the CC2340R53, but since it isn't fully validated, there is no documentation or software support. https://e2e.ti.com/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/1310169/cc2340r5-tdc-support?tisearch=e2e-sitesearch&keymatch=CC2340%20TDC#
Since this post is from over a year ago, are there any updates for when software support may be available?
