Part Number: CC2642R
Hi team,
Writing FW on CC2642R fails depending on the timing after reset. Backdoor is turned on, and CC2642R is reset. Then the FW is written after the reset pin has been deasserted. I would like to know the following
- what is the bottom threshold voltage for reset pin to be deasserted?
- is there a maximum time the reset pin can be asserted? For example, can it be asserted for few seconds?
- Is there a way to monitor whether CC2642R has waken up properly after reset?
- The FW write done 10,000us after reset works properly. However the same FW write done 100,000us after reset does not work. Is there a time-out to the FW write and/or reset? Datasheet only specifies that reset to active only takes 4000us at most.
Yu
