Is there any working "CC2640 multi role sample with CSS" ?
I tried the following:
processors.wiki.ti.com/.../Cc2640_MultiRole_Demo
But there is no CSS project available and the IAR examples fail to build. (I tried IAR 7.30.4 and 7.40.3)
So I tried the following example:
e2e.ti.com/.../424479
/cfs-file/__key/communityserver-discussions-components-files/538/Multi-CCS-patch.zip
But the CSS project also fails to build. I get the following error:
Any idea?
Thomas
Starting build of library sources ...
making C:/ti/SIMPLE~1/BLE_CC~3/Projects/ble/SimpleBLEMulti/CC26xx/CCS/Config/src/sysbios/sysbios.aem3 ...
gmake[1]: Entering directory `C:/ti/SIMPLE~1/BLE_CC~3/Projects/ble/SimpleBLEMulti/CC26xx/CCS/Config/src/sysbios'
C:/Users/tengler/AppData/Local/Temp/make38532-2.sh: line 1: syntax error: unterminated quoted string
C:/Users/tengler/AppData/Local/Temp/make38532-3.sh: line 1: syntax error: unterminated quoted string
Preprocessing library source files ...
C:/Users/tengler/AppData/Local/Temp/make38532-5.sh: line 1: syntax error: unterminated quoted string
C:/Users/tengler/AppData/Local/Temp/make38532-6.sh: line 1: syntax error: unterminated quoted string
C:/Users/tengler/AppData/Local/Temp/make38532-7.sh: line 1: syntax error: unterminated quoted string
C:/Users/tengler/AppData/Local/Temp/make38532-4.sh: line 1: syntax error: unterminated quoted string
C:/Users/tengler/AppData/Local/Temp/make38532-9.sh: line 1: syntax error: unterminated quoted string
C:/Users/tengler/AppData/Local/Temp/make38532-8.sh: line 1: syntax error: unterminated quoted string
C:/Users/tengler/AppData/Local/Temp/make38532-a.sh: line 1: syntax error: unterminated quoted string
C:/Users/tengler/AppData/Local/Temp/make38532-b.sh: line 1: syntax error: unterminated quoted string
C:/Users/tengler/AppData/Local/Temp/make38532-c.sh: line 1: syntax error: unterminated quoted string
C:/Users/tengler/AppData/Local/Temp/make38532-d.sh: line 1: syntax error: unterminated quoted string
C:/Users/tengler/AppData/Local/Temp/make38532-e.sh: line 1: syntax error: unterminated quoted string
gmake[1]: *** [mangled__BIOS_lib.pp] Error 2
gmake[1]: *** Waiting for unfinished jobs....
gmake[1]: *** [mangled_ti.sysbios.BIOS_config_lib.pp] Error 2
gmake[1]: *** [mangled_ti.sysbios.BIOS_RtsGateProxy_config_lib.pp] Error 2
C:/Users/tengler/AppData/Local/Temp/make38532-f.sh: line 1: syntax error: unterminated quoted string
gmake[1]: *** [mangled_knl_Clock_lib.pp] Error 2
gmake[1]: *** [mangled_ti.sysbios.knl.Clock_config_lib.pp] Error 2
gmake[1]: *** [mangled_knl_Idle_lib.pp] Error 2
gmake[1]: *** [mangled_knl_Intrinsics_lib.pp] Error 2
gmake[1]: *** [mangled_knl_Event_lib.pp] Error 2
gmake[1]: *** [mangled_knl_Mailbox_lib.pp] Error 2
gmake[1]: *** [mangled_ti.sysbios.knl.Mailbox_config_lib.pp] Error 2
gmake[1]: *** [mangled_knl_Queue_lib.pp] Error 2
gmake[1]: *** [mangled_ti.sysbios.knl.Queue_config_lib.pp] Error 2
gmake[1]: *** [mangled_knl_Semaphore_lib.pp] Error 2
C:/Users/tengler/AppData/Local/Temp/make38532-10.sh: line 1: syntax error: unterminated quoted string
gmake[1]: *** [mangled_ti.sysbios.knl.Semaphore_config_lib.pp] Error 2
C:/Users/tengler/AppData/Local/Temp/make38532-1.sh: line 1: syntax error: unterminated quoted string
gmake[1]: *** [mangled_knl_Swi_lib.pp] Error 2
gmake[1]: *** [mangled_knl_Swi_andn_lib.pp] Error 2
gmake[1]: Leaving directory `C:/ti/SIMPLE~1/BLE_CC~3/Projects/ble/SimpleBLEMulti/CC26xx/CCS/Config/src/sysbios'
gmake: *** [C:/ti/SIMPLE~1/BLE_CC~3/Projects/ble/SimpleBLEMulti/CC26xx/CCS/Config/src/sysbios/sysbios.aem3] Error 2
Build of libraries failed.
error: xdc.cfg.SourceDir: "C:/ti/xdctools_3_31_00_24_core/packages/xdc/cfg/SourceDir.xs", line 184: xdc.cfg.SourceDir : Build of generated source libraries failed: exit status = 2:
