--define=ICALL_STACK0_ADDR=0xf001 --define=ICALL_STACK0_START=0xf000 --define=ICALL_RAM0_START=0x20004368
name origin length used unused attr fill ---------------------- -------- --------- -------- -------- ---- -------- FLASH 00000000 0001f000 0000fc60 0000f3a0 R X SRAM 20000000 000048e7 0000057c 0000436b RW X
name origin length used unused attr fill ---------------------- -------- --------- -------- -------- ---- -------- FLASH 00000000 0000f000 0000effa 00000006 R X FLASH_LAST_PAGE 0001f000 00001000 00001000 00000000 R X SRAM 20000000 00004368 00003d3c 0000062c RW X
'Invoking: ARM Linker' "C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.6/bin/armcl" --cmd_file="C:/ti/simplelink/ble_sdk_2_02_00_31/src/config/build_components.opt" --cmd_file="C:/Users/Torsten/rcp_server/rcp_server_stack/../Config/buildConfig.opt" -mv7M3 --code_state=16 --abi=eabi -me -O4 --opt_for_speed=0 --c99 --define=USE_ICALL --define=OSAL_SNV=1 --define=FLASH_ROM_BUILD --define=POWER_SAVING --define=GATT_NO_CLIENT --define=INCLUDE_AES_DECRYPT --define=xPM_DISABLE_PWRDOWN --define=xTESTMODES --define=xTEST_BLEBOARD --define=OSAL_CBTIMER_NUM_TASKS=1 --define=xDEBUG --define=EXT_HAL_ASSERT --define=xDEBUG_GPIO --define=xDEBUG_ENC --define=xDEBUG_SW_TRACE --define=NEAR_FUNC= --define=DATA= --define=CC26XXWARE --define=CC26XX --diag_wrap=off --diag_suppress=48 --diag_suppress=16004 --display_error_number --diag_warning=225 -z -m"rcp_server_stack.map" --heap_size=0 --stack_size=256 -i"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.6/lib" -i"C:/ti/ccsv6/tools/compiler/ti-cgt-arm_5.2.6/include" --reread_libs --display_error_number --diag_wrap=off --warn_sections --diag_suppress=16002-D --diag_suppress=10247-D --diag_suppress=10325-D --diag_suppress=10229-D --xml_link_info="rcp_server_stack_linkInfo.xml" --entry_point=startup_entry --rom_model --compress_dwarf=on --unused_section_elimination=on -o "rcp_server_stack.out" "./TOOLS/onboard.obj" "./Startup/ble_user_config.obj" "./Startup/common_rom_init.obj" "./Startup/icall_startup.obj" "./Startup/osal_icall_ble.obj" "./Startup/rom_init.obj" "./PROFILES/gap.obj" "./PROFILES/gapbondmgr.obj" "./PROFILES/gattservapp_util.obj" "./OSAL/osal.obj" "./OSAL/osal_bufmgr.obj" "./OSAL/osal_cbtimer.obj" "./OSAL/osal_clock.obj" "./OSAL/osal_memory_icall.obj" "./OSAL/osal_pwrmgr.obj" "./OSAL/osal_snv_wrapper.obj" "./OSAL/osal_timers.obj" "./NPI/npi.obj" "./ICallBLE/ble_dispatch.obj" "./HAL/Target/CC2650/_common/mb_patch.obj" "./HAL/Target/CC2650/Drivers/hal_flash_wrapper.obj" "./HAL/Target/CC2650/Drivers/hal_rtc_wrapper.obj" "./HAL/Target/CC2650/Drivers/hal_trng_wrapper.obj" "./HAL/Common/hal_assert.obj" "C:/ti/simplelink/ble_sdk_2_02_00_31/src/common/cc26xx/ccs/cc26xx_stack.cmd" "C:/Users/Torsten/rcp_server/Config/ccsLinkerDefines.cmd" "C:/Users/Torsten/rcp_server/Config/lib_linker.cmd" -l"libc.a" -lC:/Users/Torsten/rcp_server/rcp_server_stack/../Config/lib_linker.cmd -l"C:/ti/simplelink/ble_sdk_2_02_00_31/src/rom/enc_lib/cc26xx_ecc_rom_api.a" -l"C:/ti/simplelink/ble_sdk_2_02_00_31/src/rom/ble_rom_releases/04242014/ble_rom_patch.symbols" -lC:/ti/tirtos_cc13xx_cc26xx_2_18_00_03/products/cc26xxware_2_23_03_17162/driverlib/bin/ccs/driverlib.lib
C:/ti/simplelink/ble_sdk_2_02_00_31/tools/frontier/frontier.exe ccs C:/Users/Torsten/rcp_server/rcp_server_stack/FlashROM/rcp_server_stack_linkInfo.xml C:/Users/Torsten/rcp_server/rcp_server_stack/../Config/ccsCompilerDefines.bcfg C:/Users/Torsten/rcp_server/rcp_server_stack/../Config/ccsLinkerDefines.cmd ' '
I think I bumped into the same issue. It looks like it is due to an incorrect link order. According to your log, cc26xx_stack.cmd is linked before ccs_linker_defines.cmd. Yet, the defines in ccs_linker_defines.cmd are required by cc26xx_stack.cmd.
I've tried setting the link order in properties/build/Link Order, but it has no effect on my linker command. It looks like there is a bug in CCS.
If you found a way to fix the link order, I'd be interested.
Valerian
