Part Number: CC2540
Can someone please help me fill out the following table of parameters requested by UL for certification of the CC2540?
EN 300 328 2.1.1 |
Parameters |
Func./Value |
Unit |
Note |
Wideband Modulations Other Than FHSS (WLAN) |
Does EUT Support CH12 and CH13? |
Yes/No |
Lowest Supported Nominal Channel Bandwidth |
MHz |
Lowest Supported Data Rate |
Mbps |
802.11 Mode at the Lowest Supported Data Rate |
11b/11g/11n |
Performance Criteria (Standard): Maximum PER (Packet Error Rate) Percentage |
Clause 5.4.1 (t) |
Performance Criteria (Other): Manufacturer Declared Limit |
Fill-in Applicable Units |
Clause 5.4.1 (t) |
Is the EUT an Adaptive or Non-Adaptive Device, or Both? |
Adaptive /Non-Adaptive / Both |
Note 2 |
Peak E.I.R.P., Low Channel (If Adaptive) |
dBm |
Note 2 |
Peak E.I.R.P., High Channel (If Adaptive) |
dBm |
Note 2 |
Medium Utilization Factor, Low Channel (If Non-Adaptive) |
Note 2 |
Medium Utilization Factor, High Channel (If Non-Adaptive) |
Note 2 |
Receiver Category |
1,2 or 3 |
Lowest Peak Antenna Gain , Low Channel |
dBi |
Note 1 |
Lowest Peak Antenna Gain , High Channel |
dBi |
Note 1 |
99% Occupied Bandwidth (Widest @ Lowest Supported Channel) |
MHz |
99% Occupied Bandwidth (Widest @ Highest Supported Channel) |
MHz |
EN 300 328 2.1.1 |
Parameters |
Func./Value |
Unit |
Note |
BLE FHSS (If Supported) |
Lowest Supported Hopping Frequency |
MHz |
Highest Supported Hopping Frequency |
MHz |
MHz |
Mbps |
Packet Type at the Lowest Supported Data Rate |
DH1/DH5/XXXX |
Modulation at the Lowest Supported Data Rate |
GFSK/8PSK |
Clause 5.4.1 (t) |
Clause 5.4.1 (t) |
Note 2 |
Peak E.I.R.P., Lowest Frequency (If Adaptive) |
dBm |
Note 2 |
Peak E.I.R.P., Highest Frequency (If Adaptive) |
dBm |
Note 2 |
Medium Utilization Factor, Lowest Frequency (If Non-Adaptive) |
Note 2 |
Medium Utilization Factor, Highest Frequency (If Non-Adaptive) |
Note 2 |
Receiver Category |
1,2 or 3 |
Lowest Peak Antenna Gain , Lowest Frequency |
dBi |
Note 1 |
Lowest Peak Antenna Gain , Highest Frequency |
dBi |
Note 1 |
99% Occupied Bandwidth (Widest @ Lowest Frequency) |
MHz |
99% Occupied Bandwidth (Widest @ Highest Frequency) |
MHz |
EN 300 328 2.1.1 |
Parameters |
Func./Value |
Unit |
Note |
BT FHSS (If Supported) |
MHz |
MHz |
MHz |
Mbps |
DH1/DH5/XXXX |
GFSK/8PSK |
Clause 5.4.1 (t) |
Clause 5.4.1 (t) |
Note 2 |
dBm |
Note 2 |
dBm |
Note 2 |
Note 2 |
Note 2 |
Receiver Category |
1,2 or 3 |
dBi |
Note 1 |
dBi |
Note 1 |
MHz |
MHz |
Note 1: Requirement to set Test Signal Threshold |
Note 2: Determines Receiver Category. |
Note 3: Please check with Chipset Vendor Compliance Group |
Note: Some Pass/Fail criteria are dependent upon vendor provided information. In the event of incomplete information the EUT will be tested in a "worst-case" scenario with an interferer amplitude of -70 dBm/MHz (based upon an antenna gain of zero dBi). |
Note: Some Pass/Fail criteria are dependent upon vendor provided information. In the event of incomplete information the EUT will be tested in a "worst-case" scenario |
