Part Number: CC2640
Hello Team,
Greetings from Z-crossing Solutions.
We are planning to do a project based on CC2640. Please find the attached schematic using CC2640. Kindly verify the same and let me know your comments.BLE_MCU.pdfBLE_MCU.pdf
Part Number: CC2640
Hello Team,
Hello Ter,
Thank you for your response.
The impedence matching circuitry is updated according to your reference design(tidrmq3). Attaching the same. As we are using PCB antenna (MIFA antenna in our design) and for flux PCB(0.4mm thickness) is this impedence matching circuitry is capable?mcu_tidrmq3(reference).pdf
NTC_TH1, NTC_TH2 are connected to the analog pins. Attaching the datasheet from CC2640 where the pin 20(DIO_7) and pin 27(DIO_14) has analog driving capability.
Attaching the latest schematic for verification.BLE_MCU1.pdf
Thanks and Regards,
Gayathri Devi
