Tool/software: TI-RTOS
I am looking for a way to implement a factory reset functionality for my CC2640R2F and I don't know where to start.
My image is that I will have a button that would fire a function to put the application back to a factory image stage after some timer expired. What should I do to implement this feature?
I assume I would need an area in flash memory to store a "default image" and that image will be loaded when the button pressed, is that correct and can you point me to the resource that helps with this function? Do I need to implement a bootloader for this?
Alex
