BOOSTXL-AOA: How to change the gain/offset of the ADCs in RF core? [AoA]
Part Number: BOOSTXL-AOA
I used the CC2640R2 and BOOSTXL-AOA antenna board to run the AoA demo code. I found out that some of the RSSI  value of the aoa packets range from about -60dbm to -65dbm when the slave board are 2 meters away from the passive board. In these packets, the values of the IQ samples are about 20(max), which are too small to calculate the phase drift. (BTW, I have fixed the bugs mentioned in this link:https://e2e.ti.com/support/wireless-connectivity/bluetooth/f/538/t/770218)
I think the quantizing noise might impact the calculation. Is there any way to use more valid bits of the RF core ADCs, like change the gain or offset?
Looking forward to your reply.
Best Regards!
