Other Parts Discussed in Thread: CC2640R2F
I am using your CC2640R2 launchXL board and i am trying to realize a secure connection pairing between device and Samsung S10. All the commands are sent from Btool application.
The CC2640R2 is flashed with Host example from simplelink_cc2640r2_sdk_4_20_00_04.
Between S10 and CC2640R2 , I realized pairing in Legacy mode (MITM and just works method).
All commands for configuring the bonding/pairing are done with GapBondMgr_SetParameter().
I will attach an log for my attempt with secure connection pair. I hope you can help me with this problem
[15] : <Tx> - 05:26:29.538
-Type : 0x01 (Command)
-OpCode : 0xFE36 (GAPBondMgr_SetParameter)
-Data Length : 0x04 (4) byte(s)
ParamID : 0x0400 (1024) (GAPBOND_PAIRING_MODE)
ParamLength : 0x01 (1)
PairingMode : 0x00 (0) (GAPBOND_PAIRING_MODE_NO_PAIRING)
Dump(Tx):
0000:01 36 FE 04 00 04 01 00 .6......
[16] : <Rx> - 05:26:29.593
-Type : 0x04 (Event)
-EventCode : 0x00FF (HCI_LE_ExtEvent)
-Data Length : 0x06 (6) bytes(s)
Event : 0x067F (1663) (GAP_HCI_ExtentionCommandStatus)
Status : 0x00 (0) (SUCCESS)
DataLength : 0x00 (0)
Dump(Rx):
0000:04 FF 06 7F 06 00 36 FE 00 ......6..
[17] : <Tx> - 05:26:37.015
ParamID : 0x0402 (1026) (GAPBOND_MITM_PROTECTION)
MitmEnable : 0x00 (0) (False)
Dump(Tx):
0000:01 36 FE 04 02 04 01 00 .6......
[18] : <Rx> - 05:26:37.070
Dump(Rx):
[19] : <Tx> - 05:26:45.369
ParamID : 0x0403 (1027) (GAPBOND_IO_CAPABILITIES)
BondIOCaps : 0x03 (3) (GAPBOND_IO_CAP_NO_INPUT_NO_OUTPUT)
Dump(Tx):
0000:01 36 FE 04 03 04 01 03 .6......
[20] : <Rx> - 05:26:45.415
Dump(Rx):
[21] : <Tx> - 05:26:50.595
ParamID : 0x0404 (1028) (GAPBOND_OOB_ENABLED)
OobEnabled : 0x00 (0) (False)
Dump(Tx):
0000:01 36 FE 04 04 04 01 00 .6......
[22] : <Rx> - 05:26:50.643
Dump(Rx):
[23] : <Tx> - 05:26:56.007
ParamID : 0x0406 (1030) (GAPBOND_BONDING_ENABLED)
BondingEnabled : 0x00 (0) (False)
Dump(Tx):
0000:01 36 FE 04 06 04 01 00 .6......
[24] : <Rx> - 05:26:56.055
Dump(Rx):
[25] : <Tx> - 05:27:07.202
ParamID : 0x0411 (1041) (GAPBOND_SECURE_CONNECTION)
BondSecureCxns : 0x01 (1) (GAPBOND_SECURE_CONNECTION_ALLOW)
Dump(Tx):
0000:01 36 FE 04 11 04 01 01 .6......
[26] : <Rx> - 05:27:07.253
Dump(Rx):
55] : <Tx> - 05:30:21.700
-OpCode : 0xFE62 (GapInit_connect)
-Data Length : 0x0A (10) byte(s)
PeerAddrType : 0x01 (1) (PEER_ADDRTYPE_RANDOM_OR_RANDOM_ID)
PeerAddr : 40:8B:FF:48:06:A1
InitiatingPhy : 0x01 (1) (
INIT_PHY_1M)
Timeout : 0x0000 (0)
Dump(Tx):
0000:01 62 FE 0A 01 A1 06 48 FF 8B 40 01 00 00 .b.....H..@...
[56] : <Rx> - 05:30:21.728
Dump(Rx):
0000:04 FF 06 7F 06 00 62 FE 00 ......b..
[57] : <Rx> - 05:30:21.918
-Data Length : 0x14 (20) bytes(s)
Event : 0x0605 (1541) (GAP_EstablishLink)
DevAddrType : 0x01 (1) (ADDRTYPE_RANDOM)
DevAddr : 40:8B:FF:48:06:A1
ConnHandle : 0x0000 (0)
ConnRole : 0x08 (8) (
Central)
ConnInterval : 0x0050 (80)
ConnLatency : 0x0000 (0)
ConnTimeout : 0x07D0 (2000)
ClockAccuracy : 0x00 (0)
Dump(Rx):
0000:04 FF 14 05 06 00 01 A1 06 48 FF 8B 40 00 00 08 .........H..@...
0010:50 00 00 00 D0 07 00 P......
[58] : <Tx> - 05:30:21.923
-OpCode : 0x2022 (HCI_LE_SetDataLength)
-Data Length : 0x06 (6) byte(s)
Handle : 0x0000 (0)
TxOctets : 0x00FB (251)
TxTime : 0x0848 (2120)
Dump(Tx):
0000:01 22 20 06 00 00 FB 00 48 08 ." .....H.
[59] : <Info> - 05:30:22.059
Device Connected
Handle = 0x0000
Addr Type = 0x01 (ADDRTYPE_RANDOM)
BDAddr = 40:8B:FF:48:06:A1
[60] : <Rx> - 05:30:21.980
-EventCode : 0x000E (HCI_CommandCompleteEvent)
Packets : 0x01 (1)
Handle : 0x0000 (0)
Dump(Rx):
0000:04 0E 06 01 22 20 00 00 00 ...." ...
[61] : <Rx> - 05:30:22.406
-EventCode : 0x003E (HCI_LE_GenericReportEvent)
-Data Length : 0x0C (12) bytes(s)
LE Event Code : 0x04 (4) (HCI_LE_ReadRemoteUsedFeaturesCompleteEvent)
ConnectionId : 0x0000 (0)
Features : 0x00000000000049FF (18943) (
Encryption
Connection_Parameters_Request
Reject_Extended_Indication
Slave_Features_Exchange
Ping
Data_Packet_Length_Extension
Privacy
Extended_Scanner_Filter_Policies
PHY_2M
Coded_PHY
Channel_Selection_Algorithm_2)
Dump(Rx):
0000:04 3E 0C 04 00 00 00 FF 49 00 00 00 00 00 00 .>......I......
[62] : <Tx> - 05:30:27.617
-Type : 0x09 (ExtCommand)
-OpCode : 0xFE48 (GAPBondMgr_Pair)
-Data Length : 0x0200 (512) byte(s)
Dump(Tx):
0000:09 48 FE 02 00 00 00 .H.....
[63] : <Rx> - 05:30:27.658
Dump(Rx):
0000:04 FF 06 7F 06 00 48 FE 00 ......H..
[64] : <Rx> - 05:30:30.116
-Data Length : 0x6B (107) bytes(s)
Event : 0x060A (1546) (GAP_AuthenticationComplete)
Status : 0x08 (8) (SMP_PAIRING_FAILED_UNSPECIFIED)
AuthState : 0x08 (8) (
Secure_Connections)
SecInf.Enable : 0x00 (0)
SecInf.LTKSize : 0x00 (0)
SecInf.LTK : 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
SecInf.DIV : 0x0000 (0)
SecInf.Rand : 00:00:00:00:00:00:00:00
DSInf.Enable : 0x00 (0) (Disable)
DSInf.LTKSize : 0x00 (0)
DSInf.LTK : 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
DSInf.DIV : 0x0000 (0)
DSInf.Rand : 00:00:00:00:00:00:00:00
IdInfo.Enable : 0x00 (0)
IdInfo.IRK : 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
IdInfo.BD_Addr : 00:00:00:00:00:00
IdInfo.AddrType: 0x00 (0) (ADDRTYPE_PUBLIC)
SignInfo.Enable: 0x00 (0) (Disable)
SignInfo.CSRK : 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
SignCounter : 0x00000000 (0)
Dump(Rx):
0000:04 FF 6B 0A 06 08 00 00 08 00 00 00 00 00 00 00 ..k.............
0010:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0020:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0030:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0040:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0050:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0060:00 00 00 00 00 00 00 00 00 00 00 00 00 00 ..............
[65] : <Info> - 05:30:33.414
Device Disconnected
Handle = 0x0000
[66] : <Rx> - 05:30:33.413
Event : 0x0606 (1542) (GAP_TerminateLink)
Reason : 0x13 (19) (PEER_REQUESTED_TERM)
Dump(Rx):
0000:04 FF 06 06 06 00 00 00 13 .........
Thank you,
Robert
