CC2640R2F: Please Review placement of Balun circuit and Small Size 2.4 GHz PCB antenna.
Part Number: CC2640R2F
Other Parts Discussed in Thread: CC2640
Hello all,
I am designing small size PCB with CC2640R2F but have little knowledge of PCB antenna design.
On my PCB, due to size restrictions, I have placed Balun & filter circuit along CC2640R2F IC. (I haven't seen this kind of placement in any document)
PCB size: 20mm x 20mm
PCB thickness: 0.4 mm
Copper Thickness : 35 um (micron)
I have referred PCB antenna design from swra117.pdf   (Small Size 2.4 GHz PCB antenna)
Desired range : ~50 feet. with 0dbm TX power.
Following is the RF  section and Layout of my PCB.
Please check whether this placement of Balun & Filter circuit and antenna will work or cause any issue.
Note: On bottom side, GND poured except antenna section.
Sharad
