Other Parts Discussed in Thread: , MSP430L092
Hi there,
We use the NFC sample code: RF430FRL15xH_Projects_v1_5\RF430FRL15xH NFC Projects\RF430FRL152H
The sample code is modified that enables the timer_A0 and ISR counts the numbers.
CCSCTL4 = SELA_1 + SELM_0 + SELS_0; // Select VLO for ACLK and select HFCLK/DCO for MCLK, and SMCLK CCSCTL5 = DIVA_2 + DIVM_1 + DIVS_1; // Set the Dividers for ACLK (4), MCLK, and SMCLK to 1 CCSCTL6 = XTOFF; // Turns of the crystal if it is not being used CCSCTL8 = ACLKREQEN + MCLKREQEN + SMCLKREQEN; //disable clocks if they are not being used TA0CCTL0 = CCIE; // Timer A0 Capture/compare interrupt enable TA0CTL = TASSEL__ACLK + // Timer_A clock source select -> ACLK MC_1 + // Mode control, Timer counts up to the value stored in TA0CCR0 ID_3; // divide 8 TA0CCR0 = 2000;
#pragma vector = TIMER0_A0_VECTOR __interrupt void TimerA0_ISR(void) { nfc_sys_data.timerCnt += 1; if(nfc_sys_data.timerCnt >= 1500) { nfc_sys_data.timerCnt = 0; } }
And, the mobile phone contacts the RF430FRL152H with NFC.
The test scenario: mobile contacts for 60 seconds then off the RF430FRL152H for 30 seconds, repeatedly. (One loop is 90 seconds).
The image shows the current of RF430FRL152H.
The current drops for 60 seconds when the mobile contacts the RF430FRL152H
The current rises for 30 seconds when the mobile off the RF430FRL152H
It crashes after testing 13 hours.
Please help if something I misses.
The code is attached.
* main.c
* RF430FRL152H NFC Only Example Project
* Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "NDEF.h"
#include "types.h"
//#include "patch.h"
#include <rf430frl152h.h>
//*****************************FUNCTION PROTOTYPES********************************/
typedef struct
u16_t ADC0_Buffer;
u08_t ADC2_Buffer;
u16_t timerCnt;
u08_t V_DOUB_time;
u08_t State;
u08_t adcProc_Start;
u08_t V_DOUB_flag;
} nfc_sys_info_t;
void DeviceInit(void);
static nfc_sys_info_t nfc_sys_data;
/*********************** SUMMARY **************************************************************************************************
* This project *only* utilizes the RF stack (ISO15693) on the ROM of the RF430FRL15xH. This setup allows the user to make a
* custom application that is run from FRAM. Only the RF13M vector that runs the RF stack needs to be pointing to its
* ROM location.
* Code Space
* Please check the lnk_rf430frl152h_NFC_Only.cmd file to customize how much code space is used for NDEF message ("FRAM_NDEF")
* or for code ("FRAM_CODE").
* Main
* Brief : Program entry.
* Param[in] : None
* Param[out]: None
* Return :
void main()
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog
// ROM RF13M module setup ** The following three lines are needed for proper RF stack operation
DS = 1; // ROM variable needs to be initialized here
asm ( " CALL #0x5CDA "); // Call ROM function ( Initialize function pointers)
asm ( " CALL #0x5CAC "); // Call ROM function ( Check part configuration)
initISO15693(CLEAR_BLOCK_LOCKS); // clear all block locks
//initISO15693(0); // leave block locks as they are set in FRAM
//JTAG is set to be disabled in this function call
DeviceInit();
while(1)
// Enter application code here...
__bis_SR_register(LPM3_bits + GIE);
* DeviceInit
* Brief : Initialize the clock system and other settings
* Patchable function
* Param[in] : parameters: has these independent options
* INITIALIZE_DEVICE_CLOCK_SYSTEM - initializes the clock system
* POPULATE_INTERRUPT_VECTOR_IN_INITIALIZATION - populate the default interrupt vectors and recalculate their CRC
* Param[out]: None
* Return None
* Patchable : Yes
// P1SEL0 = 0xF0; //keep JTAG
// P1SEL1 = 0xF0; //keep JTAG
P1SEL0 = 0x00; //no JTAG
P1SEL1 = 0x00; //no JTAG
P1DIR &= ~0xEF;
P1REN = 0;
CCSCTL0 = CCSKEY; // Unlock CCS
CCSCTL1 = 0; // do not half the clock speed
ID_3; // divide 8
TA0CCR0 = 2000; // 200
CCSCTL0_H |= 0xFF; // Lock CCS
return;
//#pragma vector = RFPMM_VECTOR
//__interrupt void RFPMM_ISR(void)
//#pragma vector = PORT1_VECTOR
//__interrupt void PORT1_ISR(void)
//#pragma vector = SD_ADC_VECTOR
//__interrupt void SD_ADC_ISR(void)
//#pragma vector = USCI_B0_VECTOR
//__interrupt void USCI_B0_ISR(void)
//#pragma CODE_SECTION(RF13M_ISR, ".fram_driver_code") // comment this line for using ROM's RF13M ISR, uncomment next one, see .cmd file for details
#pragma CODE_SECTION(RF13M_ISR, ".rf13m_rom_isr") // comment this line for creating a custom RF13M ISR that will exist in FRAM, bypassing ROM's, uncomment previous
#pragma vector = RF13M_VECTOR
__interrupt void RF13M_ISR(void)
// Right now this vector is pointing to the ROMs firmware location that runs the RF stack.
// Entering code here will, without changing the CODE_SECTION lines
// above, will cause an error.
// Changing the code section above will cause the ROM RF stack to be bypassed. New handler will need to be created.
//#pragma vector = WDT_VECTOR
//__interrupt void WDT_ISR(void)
//#pragma vector = TIMER0_A1_VECTOR
//__interrupt void TimerA1_ISR(void)
//__interrupt void TimerA0_ISR(void)
//#pragma vector = UNMI_VECTOR
//__interrupt void UNMI_ISR(void)
//#pragma vector = SYSNMI_VECTOR
//__interrupt void SysNMI_ISR(void)
lnk_rf430frl152h_NFC_Only.cmd is rename to lnk_rf430frl152h_NFC_Only.cmd.c because of the TI website upload.
/* Copyright (c) 2014, Texas Instruments Incorporated */
/* All rights reserved. */
/* Redistribution and use in source and binary forms, with or without */
/* modification, are permitted provided that the following conditions */
/* are met: */
/* * Redistributions of source code must retain the above copyright */
/* notice, this list of conditions and the following disclaimer. */
/* * Redistributions in binary form must reproduce the above copyright */
/* notice, this list of conditions and the following disclaimer in the */
/* documentation and/or other materials provided with the distribution. */
/* * Neither the name of Texas Instruments Incorporated nor the names of */
/* its contributors may be used to endorse or promote products derived */
/* from this software without specific prior written permission. */
/* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" */
/* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, */
/* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR */
/* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR */
/* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, */
/* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, */
/* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; */
/* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, */
/* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR */
/* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
/* lnk_rf430frl152h.cmd - LINKER COMMAND FILE FOR LINKING RF430FRL152H PROGRAMS */
/* Usage: lnk430 <obj files...> -o <out file> -m <map file> lnk.cmd */
/* cl430 <src files...> -z -o <out file> -m <map file> lnk.cmd */
/* These linker options are for command line linking only. For IDE linking, */
/* you should set your linker options in Project Properties */
/* -c LINK USING C CONVENTIONS */
/* -stack 0x0100 SOFTWARE STACK SIZE */
/* -heap 0x0100 HEAP AREA SIZE */
/* Version: 1.154 (Beta-Build-Tag: #0011) */
/* Specify the system memory map */
MEMORY
SFR : origin = 0x0000, length = 0x0010
PERIPHERALS_8BIT : origin = 0x0010, length = 0x00F0
PERIPHERALS_16BIT : origin = 0x0100, length = 0x0100
RAM : origin = 0x1C00, length = 0x1000
//ROM ISRs, starting points, length not correct
RF13M_ROM_ISR : origin = 0x54D0, length = 0x0002
//FRAM : origin = 0xF840, length = 0x0790
FRAM : origin = 0xF868, length = 0x011E
FRAM_CODE : origin = 0xF986, length = 0x064A // code area, can be increased / decreased with FRAM, FRAM + FRAM_CODE = 0x768
JTAGSIGNATURE : origin = 0xFFD0, length = 0x0004, fill = 0xFFFF
BSLSIGNATURE : origin = 0xFFD4, length = 0x0004, fill = 0xFFFF
INT00 : origin = 0xFFE0, length = 0x0002
INT01 : origin = 0xFFE2, length = 0x0002
INT02 : origin = 0xFFE4, length = 0x0002
INT03 : origin = 0xFFE6, length = 0x0002
INT04 : origin = 0xFFE8, length = 0x0002
INT05 : origin = 0xFFEA, length = 0x0002
INT06 : origin = 0xFFEC, length = 0x0002
INT07 : origin = 0xFFEE, length = 0x0002
INT08 : origin = 0xFFF0, length = 0x0002
INT09 : origin = 0xFFF2, length = 0x0002
INT10 : origin = 0xFFF4, length = 0x0002
INT11 : origin = 0xFFF6, length = 0x0002
INT12 : origin = 0xFFF8, length = 0x0002
INT13 : origin = 0xFFFA, length = 0x0002
INT14 : origin = 0xFFFC, length = 0x0002
RESET : origin = 0xFFFE, length = 0x0002
/* Specify the sections allocation into memory */
SECTIONS
GROUP(ALL_FRAM)
GROUP(READ_WRITE_MEMORY)
.TI.persistent : {} /* For #pragma persistent */
.cio : {} /* C I/O buffer */
.sysmem : {} /* Dynamic memory allocation area */
GROUP(READ_ONLY_MEMORY)
.cinit : {} /* Initialization tables */
.pinit : {} /* C++ constructor tables */
.init_array : {} /* C++ constructor tables */
.mspabi.exidx : {} /* C++ constructor tables */
.mspabi.extab : {} /* C++ constructor tables */
.const : {} /* Constant data */
GROUP(EXECUTABLE_MEMORY)
.text : {} /* Code */
} > FRAM_CODE
.rf13m_rom_isr : {} > RF13M_ROM_ISR type = DSECT
.fram_driver_code : {} > FRAM_CODE
.jtagsignature : {} > JTAGSIGNATURE /* JTAG Signature */
.bslsignature : {} > BSLSIGNATURE /* BSL Signature */
.jtagpassword /* JTAG Password */
.bss : {} > RAM /* Global & static vars */
.data : {} > RAM /* Global & static vars */
.TI.noinit : {} > RAM /* For #pragma noinit */
.stack : {} > RAM (HIGH) /* Software system stack */
/* MSP430 Interrupt vectors */
.int00 : {} > INT00
.int01 : {} > INT01
.int02 : {} > INT02
.int03 : {} > INT03
.int04 : {} > INT04
RFPMM : { * ( .int05 ) } > INT05 type = VECT_INIT
PORT1 : { * ( .int06 ) } > INT06 type = VECT_INIT
SD_ADC : { * ( .int07 ) } > INT07 type = VECT_INIT
USCI_B0 : { * ( .int08 ) } > INT08 type = VECT_INIT
ISO : { * ( .int09 ) } > INT09 type = VECT_INIT
WDT : { * ( .int10 ) } > INT10 type = VECT_INIT
TIMER0_A1 : { * ( .int11 ) } > INT11 type = VECT_INIT
TIMER0_A0 : { * ( .int12 ) } > INT12 type = VECT_INIT
UNMI : { * ( .int13 ) } > INT13 type = VECT_INIT
SYSNMI : { * ( .int14 ) } > INT14 type = VECT_INIT
.reset : {} > RESET /* MSP430 Reset vector */
/* Include peripherals memory map */
-l rf430frl152h.cmd
