Other Parts Discussed in Thread: MSP-EXP430F5529LP, MSP430F5529
I've been working on the MIFARE DESFire EV1 AES Authentication With TRF7970A Application Report using an MSP-EXP430F5529LP. I've managed to port the firmware properly; but the compilation process is failing because the AES_Encryption.lib needs to be re-built to run on the board I'm using. I understand that the source code is not publicly available; is there anything else I can do to get this to work?
Thank you
