产品编号:CC1310系列
while(1){
AONBatMonEnable();
// TEMPUPD.STAT = 1;
uint32_t inputt= AONBatMonTemperatureGetDegC();
#define AON_BATMON_O_TEMP 0x00000030
int32_t inputy = (int32_t)inputt; // 将uint32_t转换为int32_t
input[0] = inputt & 0xFF;
//input[0] = 1;
// 用于存储拆分后的两部分的数组
//// 将int32_t变量拆分为两部分
//uint16_t part1 = (inputy & 0xFFFF); // 取低16位
//uint16_t part2 = ((inputy >> 16) & 0xFFFF); // 取高16位
//// 将拆分后的两部分存储到数组中的第一个和第二个槽内
//input[0] = (uint8_t)(part1 & 0xFF); // 低八位存储在第一个槽内
//input[1] = (uint8_t)(part2 & 0xFF); // 高八位存储在第二个槽内
// PIN_setOutputValue(ledPinHandle, CC1310_LAUNCHXL_PIN_RLED , !PIN_getOutputValue(CC1310_LAUNCHXL_PIN_RLED ));
// usleep(10000);
// UART_write(uart, &input, 2);
Task_sleep(sleepTickCount);
AONBatMonDisable ();
/* Request access to the radio */
#if defined(DeviceFamily_CC26X0R2)
rfHandle = RF_open(&rfObject, &RF_prop, (RF_RadioSetup*)&RF_cmdPropRadioSetup, &rfParams);
#else
rfHandle = RF_open(&rfObject, &RF_prop, (RF_RadioSetup*)&RF_cmdPropRadioDivSetup, &rfParams);
#endif// DeviceFamily_CC26X0R2
// RF_cmdPropRadioDivSetup.txPower=0x913F;
//设置频率
RF_CmdHandle txTestHnle=RF_postCmd(rfHandle, (RF_Op*)&RF_cmdFs, RF_PriorityNormal, NULL, 0);
/* Create packet with incrementing sequence number and random payload */
packet[0] = input[0];
uint8_t i;
for (i = 1; i < PAYLOAD_LENGTH; i++)
packet[i] = 1;
xor_encrypt_decrypt(packet, key, PAYLOAD_LENGTH);
/* Send packet */
RF_EventMask terminationReason = RF_runCmd(rfHandle, (RF_Op*)&RF_cmdPropTx,
RF_PriorityNormal, NULL, 0);//stuck on this step
switch(terminationReason)
case RF_EventLastCmdDone:
// A stand-alone radio operation command or the last radio
// operation command in a chain finished.
break;
case RF_EventCmdCancelled:
// Command cancelled before it was started; it can be caused
// by RF_cancelCmd() or RF_flushCmd().
break;
case RF_EventCmdAborted:
// Abrupt command termination caused by RF_cancelCmd() or
// RF_flushCmd().
break;
case RF_EventCmdStopped:
// Graceful command termination caused by RF_cancelCmd() or
// RF_flushCmd().
break;
default:
// Uncaught error event
while(1);
uint32_t cmdStatus = ((volatile RF_Op*)&RF_cmdPropTx)->status;
switch(cmdStatus)
case PROP_DONE_OK:
// 传输包成功
break;
case PROP_DONE_STOPPED:
// received CMD_STOP while transmitting packet and finished
// transmitting packet
break;
case PROP_DONE_ABORT:
// Received CMD_ABORT while transmitting packet
break;
case PROP_ERROR_PAR:
// Observed illegal parameter
break;
case PROP_ERROR_NO_SETUP:
// Command sent without setting up the radio in a supported
// mode using CMD_PROP_RADIO_SETUP or CMD_RADIO_SETUP
break;
case PROP_ERROR_NO_FS:
// Command sent without the synthesizer being programmed
break;
case PROP_ERROR_TXUNF:
// TX underflow observed during operation
break;
default:
// Uncaught error event - these could come from the
// pool of states defined in rf_mailbox.h
while(1);
#ifndef POWER_MEASUREMENT
// PIN_setOutputValue(ledPinHandle, Board_PIN_LED1,!PIN_getOutputValue(Board_PIN_LED1));
#endif
/* Power down the radio */
RF_yield(rfHandle);
#ifdef POWER_MEASUREMENT
/* Sleep for PACKET_INTERVAL s */
sleep(PACKET_INTERVAL);
#else
/* Sleep for PACKET_INTERVAL us */
usleep(PACKET_INTERVAL);
#endif
RF_cancelCmd(rfHandle,txTestHnle,0);
// RF_flushCmd (rfHandle,txTestHnle,1); //擦除
RF_yield(rfHandle); //断电
RF_close(rfHandle);
以上是我的代码段,我发现调用AONBatMonDisable ();温度变成恒定的0x0A是什么原因,打开AONBatMon,如果不调用AONBatMonDisable ();就不会出现这个问题,如何解决?因为我想关掉它,降低功耗。此外,使用这个测温是否精确,精度是多少?我发现测温似乎有延迟,说明书上写着:测温需要一个周期是多久?还有我使用433MHZ,15db,Tx,发现功率达到50mA,功率过高,是使用3,6V供电,感谢解答。
