Does it matter what sync word is used in CC1200? Will FF FF FF FF be the same good as default 93 0B 51 DE(due to Wavematch technologiy)?
BR
Oleg
BR
Oleg
Yes. As I answered the sync search is correlation based. 6763.Wavematch_E2E.pptx
No matter how you search for a sync word 0xFFFF will never be a good sync word since it's just a tone and you will never know if it's a tone or noise.
Hi, Ter
Could you help me to find a source for 32-bits sync codes with a good autocorrelation properties for using with CC1200 as address. Quick search lead to scientific papers related to CDMA with just a lot of formulas.
Could you provide a list of good 32-bit sync words?
Oleg
We haven't done work on this. If you need a range of sync words I would make a Matlab script looping through all permutations and set up a rule for number of permitted sidelobes/ the amplitude for the side lobes.
If you have to use the sync word as address you should use Strict Sync Word Check ( SYNC_CFG0[1:0]). Or you should use a fixed sync word and then use the address field for filtering.
