Other Parts Discussed in Thread: CC1310, SYSBIOS, SIMPLELINK-CC13X0-SDK, CCSTUDIO
I started with a empty launcXL project for CC1310 with RTOS. I am using simplelink_cc13x0_sdk_2_40_00_20. I am getting an unresolved symbol ResetISR error.
I tried solving it by using following steps
- copy the file startup_ccs.c from C:\ti\simplelink_cc13x0_sdk_1_30_00_06\source\ti\devices\cc13x0\startup_files to your CCS project
- Under Project Properties->Build->Compiler->Include Options, add the path to the startup_files folder to --include_path (eg: "C:\ti\simplelink_cc13x0_sdk_1_30_00_06\source\ti\devices\cc13x0\startup_files")
- Under Project Properties->Build->Linker->File Search Path, add driverlib.lib to --library option, and add the path to driverlib.lib to --search_path option (eg: "C:\ti\simplelink_cc13x0_sdk_1_30_00_06\source\ti\devices\cc13x0\driverlib\bin\ccs")
I found this in one of the posts on the forum but after I do this I get several errors,
Description Resource Path Location Type
#10010 null: errors encountered during linking; "empty_CC1310_LAUNCHXL_tirtos_ccs.out" not built empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
<a href="file:/c:/ti/ccsv7/tools/compiler/dmed/HTML/10234.html">#10234-D</a> null: unresolved symbols remain empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
gmake: *** [all] Error 2 empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
gmake[1]: *** [main-build] Error 2 empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
gmake[2]: *** [empty_CC1310_LAUNCHXL_tirtos_ccs.out] Error 1 empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
gmake[2]: Target 'secondary-outputs' not remade because of errors. empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol pthread_attr_init, first referenced in ./main_tirtos.obj empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol pthread_attr_setdetachstate, first referenced in ./main_tirtos.obj empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol pthread_attr_setschedparam, first referenced in ./main_tirtos.obj empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol pthread_attr_setstacksize, first referenced in ./main_tirtos.obj empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol pthread_create, first referenced in ./main_tirtos.obj empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol sleep, first referenced in ./empty.obj empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_BIOS_getCpuFreq__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<ClockP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_BIOS_start__E, first referenced in ./main_tirtos.obj empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_family_arm_m3_Hwi_clearInterrupt__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<HwiP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_family_arm_m3_Hwi_construct2__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<HwiP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_family_arm_m3_Hwi_destruct, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<HwiP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_family_arm_m3_Hwi_disableFxn__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<HwiP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_family_arm_m3_Hwi_Params__init__S, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<HwiP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_family_arm_m3_Hwi_restoreFxn__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<HwiP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_family_arm_m3_Hwi_swiDisable__C, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<PowerCC26XX_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_family_arm_m3_Hwi_swiRestoreHwi__C, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<PowerCC26XX_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Clock_construct, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<ClockP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Clock_destruct, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<ClockP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Clock_getTicksUntilInterrupt__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<PowerCC26XX_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Clock_Params__init__S, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<ClockP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Clock_setTimeout__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<ClockP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Clock_start__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<ClockP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Clock_stop__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<ClockP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Clock_tickPeriod__C, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<ClockP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Semaphore_construct, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SemaphoreP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Semaphore_create, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SemaphoreP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Semaphore_delete, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SemaphoreP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Semaphore_destruct, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SemaphoreP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Semaphore_Params__init__S, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SemaphoreP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Semaphore_pend__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SemaphoreP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Semaphore_post__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SemaphoreP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Swi_construct2__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SwiP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Swi_destruct, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SwiP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Swi_disable__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SwiP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Swi_getTrigger__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SwiP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Swi_or__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SwiP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Swi_Params__init__S, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SwiP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Swi_restore__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SwiP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Task_disable__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<PowerCC26XX_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol ti_sysbios_knl_Task_restore__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<PowerCC26XX_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol xdc_runtime_Error_IgnoreBlock, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<ClockP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
unresolved symbol xdc_runtime_System_vsnprintf__E, first referenced in C:/ti/simplelink_cc13x0_sdk_2_40_00_20/kernel/tirtos/packages/ti/dpl/lib/dpl_cc13x0.aem3<SystemP_tirtos.oem3> empty_CC1310_LAUNCHXL_tirtos_ccs C/C++ Problem
I am not sure if the method i used to resolving the issue is correct since it was used for a older SDK.
Thank you in advance for help.
