I using the WiLink8 Calibration Tool
I am confused by the "Set TX Power" command. More specifically, the "antenna" parameter. I'm trying to correspond the allowed antenna values to the actual pin on the WL1837MOD wifi module.
If I set the antenna parameter to 1, what WL1837MOD pin will the test signal be applied to? I would assume RF_ANT1 (pin32). Likewise, if I set the antenna parameter to 2, what WL1837MOD pin will the test signal be applied to? Again, I would assume RF_ANT2 (pin 18). I'm asking because actual behavior seems opposite.
