Linux/WL1835MODCOM8B: Unable to discove WL1835MODCOM8B on DRA71x EVM
Part Number: WL1835MODCOM8B
Other Parts Discussed in Thread: WL1835
Tool/software: Linux
Below is the config we did on DRA76x dts file for bringing up WL1835com8B on Jacinto6Plus but we are facing issues i:e its not getting detected
Is there any switch we need to enable on jacinto6Plus ?
Thanks in advance
vmmcwl_fixed: fixedregulator-mmcwl {
                compatible = "regulator-fixed";
                regulator-name = "vmmcwl_fixed";
                regulator-min-microvolt = <1800000>;
                regulator-max-microvolt = <1800000>;
                gpio = <&gpio5 8 0>;    /* gpio5_8 */
                startup-delay-us = <70000>;
                enable-active-high;
mmc4_pins_default: mmc4_pins_default {
        pinctrl-single,pins = <
            DRA7XX_CORE_IOPAD(0x37e8, PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE3) /* uart1_ctsn.mmc4_clk */
            DRA7XX_CORE_IOPAD(0x37ec, PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE3) /* uart1_rtsn.mmc4_cmd */
            DRA7XX_CORE_IOPAD(0x37f0, PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE3) /* uart2_rxd.mmc4_dat0 */
            DRA7XX_CORE_IOPAD(0x37f4, PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE3) /* uart2_txd.mmc4_dat1 */
            DRA7XX_CORE_IOPAD(0x37f8, PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE3) /* uart2_ctsn.mmc4_dat2 */
            DRA7XX_CORE_IOPAD(0x37fc, PIN_INPUT_PULLUP | MODE_SELECT | MUX_MODE3) /* uart2_rtsn.mmc4_dat3 */
    mmc4_pins_sdr12: mmc4_pins_sdr12 {
    mmc4_pins_hs: mmc4_pins_hs {
    mmc4_pins_sdr25: mmc4_pins_sdr25 {
&mmc4 {
        status = "okay";
        vmmc-supply = <&vmmcwl_fixed>;
        bus-width = <4>;
        pinctrl-names = "default", "hs", "sdr12", "sdr25";
        pinctrl-0 = <&mmc4_pins_hs &mmc4_iodelay_default_conf>;
        pinctrl-1 = <&mmc4_pins_hs &mmc4_iodelay_manual1_conf>;
        pinctrl-2 = <&mmc4_pins_hs &mmc4_iodelay_manual1_conf>;
        pinctrl-3 = <&mmc4_pins_hs &mmc4_iodelay_manual1_conf>;
        cap-power-off-card;
        keep-power-in-suspend;
        ti,non-removable;
        #address-cells = <1>;
        #size-cells = <0>;
        wlcore: wlcore@2 {
                compatible = "ti,wl1835";
                reg = <2>;
                interrupt-parent = <&gpio5>;
                interrupts = <7 IRQ_TYPE_EDGE_RISING>;
