Part Number: WL1807MOD
Hi Champs,
We tried to fix previous question with several approach. So, we would like to know driver side.
[Question 1]
/usr/sbin/wlconf/default.conf file
core.rx_streaming.duration parameter.
What kind of function relate it ?
[Question 2]
Accourding to previous discussion, ACK_timeout can't control.
However, when we look into hostapd の src/ap/wmm.c にあるwmm_process_tspec() function
duration setting , this ★area seems relate ACK_timeout.
Could you please double check if this relate time out issue ?
int wmm_process_tspec(struct wmm_tspec_element *tspec) {
duration = (le_to_host16(tspec->nominal_msdu_size) & 0x7fff) * 8 / ★
(le_to_host32(tspec->minimum_phy_rate) / 1000000) +
50 /* FIX: proper SIFS + ACK duration */;
