WL1831MOD: Override wl18xx config in yocto.
Part Number: WL1831MOD
Other Parts Discussed in Thread: AM3352
We are seeing disconnects using a WL18xx module on a am3352 processor. The answer in seems to do the trick. However, I am trying to override the meta-ti/recipes-connectivity/wlconf to use the updated configuration instead of the default one.
Tried to do it with a bbappend but it fails to find the new file.
S_HW = "${WORKDIR}/git/hw/firmware"
FILESEXTRAPATHS_prepend := "${THISDIR}/${PN}:"
SRC_URI_append_${PN} = " file://wl18xx-conf-2.4GHz-Only.bin \
do_install_append() {
   install -m 0755 ${S_HW}/wl1271-nvs.bin \
           ${D}/lib/firmware/ti-connectivity
   install -m 0755 ${WORKDIR}/wl18xx-conf-2.4GHz-Only.bin \
           ${D}/lib/firmware/ti-connectivity/wl18xx-conf.bin
FILES_${PN} += " \
    /lib/firmware/ti-connectivity/wl1271-nvs.bin \
    /lib/firmware/ti-connectivity/wl18xx-conf-2.4GHz-Only.bin \
The bbappend file previously worked for adding the wl1271-nvs.bin. Yocto complains about not finding wl18xx-conf-2.4GHz-Only.bin. It does not get copied to the work directory.
  • Found the solution. The append recipe needed some motifications:
    SRC_URI_append = " file://wl18xx-conf-2.4GHz-Only.bin \
    FILES_${PN} += " \
    Thanks for updating the thread. Best of luck with your project
    Saurabh
