Part Number: CC2652P
Hello All,
I am using CC2652P & simplink sdk v5.20 based ZNP along for Raspberry pi over UART and zigbee 3.0 linux gateway.
The Gateway has stopped working after being operational for around 1 year.
here is the details/log when we start - ./zigbeeHAGW service -
Platform type selected automatically as bbb.
To override this selection, please stop this script, and then run it again,
specifying the desired platform type at the command line:
./zigbeeHAgw [help | bbb | x86 ]
running ./zigbeeHAgw on an ARM
done processing arguments, board type bbb, target arm
NPI is 'NPI_lnx_arm_server'
Zstack linux server is 'ZLSZNP_arm'
gateway server is 'GATEWAY_SRVR_arm'
network manager is 'NWKMGR_SRVR_arm'
OTA server is 'OTA_SRVR_arm'
Starting the ZigBee gateway subsystem
making sure there are no lingering servers...
there are 0 NPI servers
there are 0 ZLS servers
there are 0 GATEWAY servers
there are 0 NWKMGR servers
there are 0 OTA servers
(total 0)
done
starting NPI, cmd ' ./NPI_lnx_arm_server NPI_Gateway.cfg ' on Sat 25 Feb 11:55:22 IST 2023
[11:55:22.913,762] [NPISRVR/MAIN] UNMSKBL:
[11:55:22.914,012] [NPISRVR/MAIN] UNMSKBL: ************************************************
[11:55:22.914,033] [NPISRVR/MAIN] UNMSKBL: * NPI Server v1.0.2d *
[11:55:22.914,046] [NPISRVR/MAIN] UNMSKBL: ************************************************
[11:55:22.914,057] [NPISRVR/MAIN] UNMSKBL:
getaddrinfo error: Servname not supported for ai_socktype
Startup phase 1 completed successfully, server started (NPI_PID=5787) on Sat 25 Feb 11:55:22 IST 2023
starting ZLSZNP, cmd ' ' on Sat 25 Feb 11:55:22 IST 2023
[11:55:22.933,233] [Z_STACK/MAIN] UNMSKBL:
[11:55:22.933,376] [Z_STACK/MAIN] UNMSKBL: ************************************************
[11:55:22.933,395] [Z_STACK/MAIN] UNMSKBL: * ZStack Server for ZNP v1.0.2d *
[11:55:22.933,407] [Z_STACK/MAIN] UNMSKBL: ************************************************
[11:55:22.933,447] [Z_STACK/MAIN] UNMSKBL:
[11:55:24.933,756] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[11:55:24.933,802] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[11:55:26.933,996] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[11:55:26.934,052] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[11:55:28.934,312] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[11:55:28.934,405] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[11:55:30.934,679] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[11:55:30.934,756] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
^Ccaught SIGTERM, killing all the servers and cleaning up
waiting for NPI to exit
recv: Connection reset by peer
there are 1 ZLS servers
(total 1)
^C^C./zigbeeHAgw: line 560: 0 + 0 + 0 + 0 + : syntax error: operand expected (error token is "+ ")
Startup phase 2 failed
waiting for netmgr to exit ( pid 0 ) on Sat 25 Feb 11:55:31 IST 2023
./zigbeeHAgw: line 998: wait: pid 0 is not a child of this shell
oops! Network manager has already exited (!) on Sat 25 Feb 11:55:31 IST 2023
I am killing myself will not take further action
./zigbeeHAgw exiting
(total 0)
done
terminating zigbeeHAGW (pid 5650)
Killed
Db50Gw@ftzbgw:~/zigbee_gateway_v3.0/out/Precompiled/servers $ clrscreen
bash: clrscreen: command not found
Db50Gw@ftzbgw:~/zigbee_gateway_v3.0/out/Precompiled/servers $ ./zigbeeHAgw
set gpio 22 mode
set gpio 22 low
set gpio 22 high
start gateway
./zigbeeHAgw: line 56: l: command not found
(total 0)
done
starting NPI, cmd ' ./NPI_lnx_arm_server NPI_Gateway.cfg ' on Sat 25 Feb 12:05:19 IST 2023
[12:05:19.068,901] [NPISRVR/MAIN] UNMSKBL:
[12:05:19.069,287] [NPISRVR/MAIN] UNMSKBL: ************************************************
[12:05:19.069,320] [NPISRVR/MAIN] UNMSKBL: * NPI Server v1.0.2d *
[12:05:19.069,346] [NPISRVR/MAIN] UNMSKBL: ************************************************
[12:05:19.069,369] [NPISRVR/MAIN] UNMSKBL:
Startup phase 1 completed successfully, server started (NPI_PID=7789) on Sat 25 Feb 12:05:19 IST 2023
starting ZLSZNP, cmd ' ' on Sat 25 Feb 12:05:19 IST 2023
[12:05:19.108,182] [Z_STACK/MAIN] UNMSKBL:
[12:05:19.108,430] [Z_STACK/MAIN] UNMSKBL: ************************************************
[12:05:19.108,463] [Z_STACK/MAIN] UNMSKBL: * ZStack Server for ZNP v1.0.2d *
[12:05:19.108,488] [Z_STACK/MAIN] UNMSKBL: ************************************************
[12:05:19.108,511] [Z_STACK/MAIN] UNMSKBL:
[12:05:21.108,905] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:21.108,977] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:23.109,240] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:23.109,299] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:25.109,530] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:25.109,593] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:27.109,928] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:27.110,021] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:29.110,284] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:29.110,331] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:31.110,527] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:31.110,614] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:33.110,903] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:33.110,989] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:35.111,279] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:35.111,367] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:37.111,658] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:37.111,751] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
Startup phase 2 completed successfully, server started (ZLSZNP_PID=7795) on Sat 25 Feb 12:05:37 IST 2023
starting NETWORK_MGR, cmd ' ./NWKMGR_SRVR_arm 127.0.0.1:2536 ' on Sat 25 Feb 12:05:37 IST 2023
[12:05:37.163,820] [NWK_MGR/MAIN] UNMSKBL:
[12:05:37.164,180] [NWK_MGR/MAIN] UNMSKBL: ************************************************
[12:05:37.164,216] [NWK_MGR/MAIN] UNMSKBL: * Network Manager Server v1.0.2d *
[12:05:37.164,245] [NWK_MGR/MAIN] UNMSKBL: ************************************************
[12:05:37.164,271] [NWK_MGR/MAIN] UNMSKBL:
[12:05:39.113,829] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:39.113,928] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:39.169,818] [NWK_MGR/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:39.169,912] [NWK_MGR/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:39.170,102] [NWK_MGR/MAIN] ERROR : ERROR: signal 11 was trigerred:
[12:05:39.170,156] [NWK_MGR/MAIN] ERROR : Fault address: (nil)
[12:05:39.170,202] [NWK_MGR/MAIN] ERROR : Fault reason: address not mapped to object
[12:05:39.171,091] [NWK_MGR/MAIN] ERROR : Stack trace unavailable
[12:05:39.171,167] [NWK_MGR/MAIN] ERROR : Executing original handler...
Startup phase 3 failed
waiting for Zstack linux to exit
(total 0)
done
Executing reset from external scripts
starting NPI, cmd ' ./NPI_lnx_arm_server NPI_Gateway.cfg ' on Sat 25 Feb 12:05:43 IST 2023
[12:05:43.531,831] [NPISRVR/MAIN] UNMSKBL:
[12:05:43.532,529] [NPISRVR/MAIN] UNMSKBL: ************************************************
[12:05:43.532,573] [NPISRVR/MAIN] UNMSKBL: * NPI Server v1.0.2d *
[12:05:43.532,625] [NPISRVR/MAIN] UNMSKBL: ************************************************
[12:05:43.532,656] [NPISRVR/MAIN] UNMSKBL:
Startup phase 1 completed successfully, server started (NPI_PID=7899) on Sat 25 Feb 12:05:43 IST 2023
starting ZLSZNP, cmd ' ' on Sat 25 Feb 12:05:43 IST 2023
[12:05:43.577,785] [Z_STACK/MAIN] UNMSKBL:
[12:05:43.578,098] [Z_STACK/MAIN] UNMSKBL: ************************************************
[12:05:43.578,137] [Z_STACK/MAIN] UNMSKBL: * ZStack Server for ZNP v1.0.2d *
[12:05:43.578,168] [Z_STACK/MAIN] UNMSKBL: ************************************************
[12:05:43.578,200] [Z_STACK/MAIN] UNMSKBL:
[12:05:45.578,942] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:45.578,996] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:47.579,198] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:47.579,277] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:49.579,536] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:49.579,615] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:51.579,907] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:51.579,970] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:53.580,165] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:53.580,242] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:55.580,495] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:55.580,569] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:57.580,954] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:57.581,001] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:05:59.581,190] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:05:59.581,266] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:06:01.581,571] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:06:01.581,624] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
Startup phase 2 completed successfully, server started (ZLSZNP_PID=7905) on Sat 25 Feb 12:06:01 IST 2023
starting NETWORK_MGR, cmd ' ./NWKMGR_SRVR_arm 127.0.0.1:2536 ' on Sat 25 Feb 12:06:01 IST 2023
[12:06:01.603,132] [NWK_MGR/MAIN] UNMSKBL:
[12:06:01.603,747] [NWK_MGR/MAIN] UNMSKBL: ************************************************
[12:06:01.603,764] [NWK_MGR/MAIN] UNMSKBL: * Network Manager Server v1.0.2d *
[12:06:01.603,778] [NWK_MGR/MAIN] UNMSKBL: ************************************************
[12:06:01.603,789] [NWK_MGR/MAIN] UNMSKBL:
[12:06:03.582,686] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:06:03.582,741] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:06:03.605,746] [NWK_MGR/MAIN] ERROR : SRSP Cond Wait timed out!
[12:06:03.605,962] [NWK_MGR/MAIN] ERROR : apicSendSynchData() failed getting response
[12:06:03.606,065] [NWK_MGR/MAIN] ERROR : ERROR: signal 11 was trigerred:
[12:06:03.606,088] [NWK_MGR/MAIN] ERROR : Fault address: (nil)
[12:06:03.606,100] [NWK_MGR/MAIN] ERROR : Fault reason: address not mapped to object
[12:06:03.606,504] [NWK_MGR/MAIN] ERROR : Stack trace unavailable
[12:06:03.606,539] [NWK_MGR/MAIN] ERROR : Executing original handler...
(total 0)
done
starting NPI, cmd ' ./NPI_lnx_arm_server NPI_Gateway.cfg ' on Sat 25 Feb 12:06:07 IST 2023
[12:06:07.883,356] [NPISRVR/MAIN] UNMSKBL:
[12:06:07.883,752] [NPISRVR/MAIN] UNMSKBL: ************************************************
[12:06:07.883,783] [NPISRVR/MAIN] UNMSKBL: * NPI Server v1.0.2d *
[12:06:07.883,812] [NPISRVR/MAIN] UNMSKBL: ************************************************
[12:06:07.883,835] [NPISRVR/MAIN] UNMSKBL:
Startup phase 1 completed successfully, server started (NPI_PID=8009) on Sat 25 Feb 12:06:07 IST 2023
starting ZLSZNP, cmd ' ' on Sat 25 Feb 12:06:07 IST 2023
[12:06:07.937,669] [Z_STACK/MAIN] UNMSKBL:
[12:06:07.938,043] [Z_STACK/MAIN] UNMSKBL: ************************************************
[12:06:07.938,076] [Z_STACK/MAIN] UNMSKBL: * ZStack Server for ZNP v1.0.2d *
[12:06:07.938,102] [Z_STACK/MAIN] UNMSKBL: ************************************************
[12:06:07.938,126] [Z_STACK/MAIN] UNMSKBL:
[12:06:09.939,051] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:06:09.939,132] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:06:11.939,416] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:06:11.939,499] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:06:13.939,792] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:06:13.939,876] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:06:15.940,159] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:06:15.940,237] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:06:17.940,493] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:06:17.940,582] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:06:19.941,025] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:06:19.941,073] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:06:21.941,320] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:06:21.941,399] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:06:23.941,655] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:06:23.941,733] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[12:06:25.941,988] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[12:06:25.942,039] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
Startup phase 2 completed successfully, server started (ZLSZNP_PID=8015) on Sat 25 Feb 12:06:25 IST 2023
starting NETWORK_MGR, cmd ' ./NWKMGR_SRVR_arm 127.0.0.1:2536 ' on Sat 25 Feb 12:06:25 IST 2023
[12:06:25.961,270] [NWK_MGR/MAIN] UNMSKBL:
[12:06:25.961,476] [NWK_MGR/MAIN] UNMSKBL: ************************************************
[12:06:25.961,491] [NWK_MGR/MAIN] UNMSKBL: * Network Manager Server v1.0.2d *
[12:06:25.961,504] [NWK_MGR/MAIN] UNMSKBL: ************************************************
[12:06:25.961,515] [NWK_MGR/MAIN] UNMSKBL:
there are 1 NWKMGR servers
(total 1)
^C^C./zigbeeHAgw: line 571: 0 + 0 + 0 + 1 + : syntax error: operand expected (error token is "+ ")
(total 1)
[12:06:27.963,233] [NWK_MGR/MAIN] ERROR : SRSP Cond Wait timed out!
[12:06:27.963,280] [NWK_MGR/MAIN] ERROR : apicSendSynchData() failed getting response
[12:06:27.963,384] [NWK_MGR/MAIN] ERROR : ERROR: signal 11 was trigerred:
[12:06:27.963,404] [NWK_MGR/MAIN] ERROR : Fault address: (nil)
[12:06:27.963,422] [NWK_MGR/MAIN] ERROR : Fault reason: address not mapped to object
[12:06:27.963,829] [NWK_MGR/MAIN] ERROR : Stack trace unavailable
[12:06:27.963,863] [NWK_MGR/MAIN] ERROR : Executing original handler...
(total 0)
done
terminating zigbeeHAGW (pid 7638)
Killed
How can I troubleshoot further, any suggestions plz.
Dhanraj
