Part Number: CC2652P7
Other Parts Discussed in Thread: CC1352P7, SYSCONFIG
I cannot select "another compatible device or core" in CCS project option or syscofnig edit.
How can I conveniently switch the target chip on an existing project?
Thanks.
Hi Howjie,
You will need to import a LP-CC1352P7-4 project as a base and migrate your application changes accordingly. software-on-cc13x2x7-26x2x7.html
Ryan
Hi Ryan,
In the LP-CC1352P7-4 project (dmm_zc_switch_remote_display_app_LP_CC1352P7_4_tirtos7_ticlang), I cannot switch back to "switch" after switching the device to "customer board" in syscfg. At this point, the options are not optional (gray).
How to deal with this situation?
Howjie
You can replace your edited SysConfig file with the original SDK\examples\rtos\LP_CC1352P7_4\dmm\dmm_zc_switch_remote_display_app\tirtos7\dmm_zc_switch_remote_display.syscfg version if you are attempting to revert changes you did not intend to make. The SysConfig Switch tool is underdeveloped and thus should not be used to migrate projects to different device variants.
Ryan
