Other Parts Discussed in Thread: CC2630
I am looking at an application which, due to physical layout, requires routers to be very low power (battery operated) and therefore able to sleep between communications to maintain a suitable power budget.
I have seen articles that suggest that Zigbee does not support sleeping routers, however I saw this old article with a similar problem, and something of a possible solution:
This article is now quite old, I wondered if there was now some more knowledge on what I am would have thought to be not such an unusual use-case.
For some more back ground, information transfer is only required between each node and the coordinator, generally for the reporting of measured data.
Looking to use the CC2630
