Part Number: CC2530
Other Parts Discussed in Thread: Z-STACK, CC-DEBUGGER
I'm using a CC2530 PA1 module but it does not have pins P1.4 to P1.7.Is it possible to guide me?
Part Number: CC2530
Don't try to use the CC-DEBUGGER as a communication bridge between your Zigbee application and PC. It is only for programming and debugging. You need to use the UART peripheral as demonstrated in the ZNP project, but your case would most likely use the ZAPP_P[1/2] definition to communicate temperature values to your PC outside of Z-Tool. Pin usage varies depending on your HAL_UART_[DMA/UART] defines.
Edit: Thread closed as the customer discovered through other posts that the CC2530 does have P1_4 through P1_7 pinouts but not on their EVM.
Ryan
