Hi all,
When TLV320AIC3204 entered the shutdown mode which is set by below application note method
(AVDD is off),
is the I2C condition Hi-Z?
http://www.ti.com/lit/pdf/slaa473
Toshi
Hi all,
(AVDD is off),
Toshi
Hi Toshi,
I will move this question to the correct forum. The SDA and SCL lines of the device are designed to prevent the device from dragging down the bus when the device is put in shutdown or power is removed.
-Diego Meléndez López
Audio Applications Engineer
