We evaluate thermal specificaiont of the TAS6424 for my customer.
Is suffix No. of following picture latest version?
And is this version appropriate of thermal evaluation?
Kuramochi
Kuramochi
Gregg-san,
Thank you for your support.
This sample shuts down by DC ERROR when outputting 15W*4 on 2ohm load.
Is this correct working?
If it is, the TAS6424 is not matching for my customer requiring....
Kuramochi
Gregg-san,
I'm sorry for may late replying.
>1. Does the fault occur on all channels?
Please refer the following picture.
>2. What type of signal is the customer using? Sine, Square, ??
This is music source.
>3. What is the power supply voltage on PVDD when this occurs?
PVDD is 14V.
Kuramochi
Kuramochi-san,
This is a curious result in your GUI. We will investigate and get back to you.
Kuramochi-san,
The OTSD will shut the device down when it is too hot. Please check the heatsink interface to the device. We have found that some of the heatsinks do not have the proper amount of heatsink compound. Please check and made sure there is a very thin and evenly spread layer of white heatsink compound.
Gregg-san,
Thank you for your comment.
I confirm the heatsink.
Do you have actual thermal measurement data on the same or similar condition(15W*4ch on 2ohm load)?
We would like to refer it.
Kuramochi
