Hi all
Would you mind if we ask TPA2038D1?
Input coupling capacitor(AC coupling) on TPA2038D1YFFEVM is 0.1uF.
In case of AV = 6 dB : the cutoff frequency will be 21.2Hz
In case of AV = 12 dB : the cutoff frequency will be 10.6Hz
In generally, we guess that the big capacitance value will be cause of pop-noise.
So, in case of using 0.1uF, as your experience, is it no level which you worry pop-noise?
If you have some advice, please let us.
Kind regards,
Hirotaka Matsumoto
