Hello dear Ti.
I just wanted to clarify some thing.
There is often mentioned that good decoupling is critical for system stability and performance.
But is definitely rare mentioning which decoupling method, classis - I mean between supply line and ground or between both rails (exluding ground).
So question is when should I use rail-to-rail decoupling in my desing and when it's not needed (or should be avoided).
In my case loads are connected to ground.
Another question is, should I use rail-to-rail decoupling (if needed) in close proximity to every opamp (lets asume I will place a capacitor on the bottom plane, directly below opamp) or maybe it's not critical? And I can place those cap/s closer to main LDO's.
