TAS5709: TAS5709 high THD+N @ low output power
Part Number: TAS5709
Hi, team,
My customer is using TAS5709, found THD+N is very large when the Master volume is small. As the red font shown in the following table.  For example, when the Master Volume= 0x72, THD+N reaches 80.1%. This should not be related to noise. Please help to analyze the issue, thank you!
Input Signal
Master Volume
L
R
Output Power (W)
THD+N (%)
Output Power (W)
THD+N (%)
1000Hz_-9dB.wav
0x24
8.21
0.423
8.11
0.341
1000Hz_-9dB.wav
0x27
5.887
0.306
5.797
0.237
1000Hz_-9dB.wav
0x2A
4.192
0.214
4.131
0.161
1000Hz_-9dB.wav
0x2D
2.984
0.155
2.93
0.117
1000Hz_-9dB.wav
0x30
2.116
0.12
2.081
0.09
1000Hz_-9dB.wav
0x33
1.502
0.103
1.473
0.075
1000Hz_-9dB.wav
0x36
1.064
0.08
1.045
0.057
1000Hz_-9dB.wav
0x39
0.756
0.052
0.739
0.041
1000Hz_-9dB.wav
0x3C
0.536
0.04
0.526
0.034
1000Hz_-9dB.wav
0x3F
0.3784
0.033
0.3715
0.031
1000Hz_-9dB.wav
0x42
0.2675
0.031
0.2631
0.03
1000Hz_-9dB.wav
0x45
0.1894
0.032
0.1859
0.032
1000Hz_-9dB.wav
0x48
0.134
0.0031
0.132
0.031
1000Hz_-9dB.wav
0x4B
0.0949
0.034
0.0931
0.034
1000Hz_-9dB.wav
0x4E
0.067
0.039
0.066
0.038
1000Hz_-9dB.wav
0x51
0.0475
0.04
0.0467
0.04
1000Hz_-9dB.wav
0x54
0.0337
0.06
0.0331
0.06
1000Hz_-9dB.wav
0x57
0.0239
0.07
0.0235
0.07
1000Hz_-9dB.wav
0x5A
0.017
0.08
0.0167
0.08
1000Hz_-9dB.wav
0x5D
0.012
0.094
0.012
0.096
1000Hz_-9dB.wav
0x60
0.0086
0.11
0.0085
0.11
1000Hz_-9dB.wav
0x63
0.0061
0.11
0.006
0.13
1000Hz_-9dB.wav
0x66
0.0044
0.13
0.0043
0.13
1000Hz_-9dB.wav
0x69
0.0032
0.15
0.0031
0.15
1000Hz_-9dB.wav
0x6C
0.0023
0.17
0.0023
0.17
1000Hz_-9dB.wav
0x6F
1.69 mW
0.8
1.67 mW
1.7
1000Hz_-9dB.wav
0x72
1.25 mW
20
1.25 mW
40
1000Hz_-9dB.wav
0x7B
580 uW
80.1
590 uW
78.7
1000Hz_-9dB.wav
0x7E
470 uW
74
483 uW
72
1000Hz_-9dB.wav
0x87
303 uW
55.3
318 uW
53.6
1000Hz_-9dB.wav
0x8D
256 uW
42
272 uW
40.6
1000Hz_-9dB.wav
0x96
225 uW
26.8
243 uW
25.7
1000Hz_-9dB.wav
0x99
220 uW
22.8
237 uW
21.8
1000Hz_-9dB.wav
0x9C
216 uW
19.3
235 uW
18.5
1000Hz_-9dB.wav
0xAE
212 uW
7
227 uW
6.7
1000Hz_-9dB.wav
0xBD
211 uW
2.9
227 uW
2.7
1000Hz_-9dB.wav
0xC0
210 uW
2.43
226 uW
2.3
1000Hz_-9dB.wav
0xC3
210 uW
2.03
226 uW
1.95
1000Hz_-9dB.wav
0xC6
210 uW
1.72
226 uW
1.65
1000Hz_-9dB.wav
0xC9
210 uW
1.48
226 uW
1.42
1000Hz_-9dB.wav
0xCC
209 uW
1.26
226 uW
1.21
  • Hi Nicole,
    I think this data looks reasonable. When the output power is very low, the THD+N performance is dominated by noise actually. Since the noise floor is constant, the THD+N performance degrades with output power decreases. For the very low output power (e.g. uW level), it makes no sense for the mid-power class-d device evaluation. Please refer to this document(www.ti.com/.../slaa114.pdf), we have very detailed explanation on Page 11 and 12 in it.
    Shawn Zheng
  • Hi, Shawn,
    I couldn't find the document. could you share it again?
    I thought it was caused by noise at the beginning, but you can see from THD+N became 80% at580uW, then it started to become better. If this is caused by noise, THD+N can only become worse with the drop of output power.
    I also checked it on TPA3118 EVM, and found it doesn't get worse so fast.
  • Hi Nicole,
    The previous link is bad, please try this one. www.ti.com/.../slaa114.pdf
    You could find detailed info about THD measurement on Page 11 and 12. Again, it makes no sense for THD+N measurement with so low output power. In this case, AP even can't distinguish the valid signal from the noise floor. Can you read the measured frequency from AP? Is it expected and stable? If not, the measured THD+N number is not trust worth.
    Shawn Zheng
  • Hi Nicole,
    As we talked about this on phone, I believe this question has already been resolved. Could you please help to close it? Thanks!
    Shawn Zheng
