  • TI Thinks Resolved
TPA2029D1: The electrical characteristics of RL=4ohm
Part Number: TPA2029D1
Hi Team,
Please help to provide the electrical characteristics of RL=4ohm.
We now use 4ohm speaker, but datasheet only list the parameter on RL=8ohm.
Please kindly help.
  • Hi Daniel,
    The data sheet show some 4 ohm load specs. What would be the characteristics you need for 4 ohm load?
    -Ivan Salazar
    Applications Engineer - Low Power Audio & Actuators
  • In reply to Ivan Salazar:
    Dear Ivan,
    The electrical characteristic of datasheet based on 8 ohm. And almost all graphs are all for 8 ohm.
    Please provide related 4 ohm data.
  • In reply to daniel:
    Daniel,
    Attached are a couple graphs for 4 Ohm load. As you can see the performance is pretty much the same as 8 ohm load, this is mainly due to the AGC and compressor.
    Data sheet includes THD+N vs Freq and vs Output Power, as well as efficiency, power dissipation, output power vs power supply, all these for both 4 and 8 ohm loads.
    -Ivan Salazar
    Dear Ivan,
    Thanks for your support
    Please kindly help to provide the graph as figure2~figure9 in data sheet for 4ohm.
    Customer request these graph data to design in.
    Many thanks
    Daniel,
    You can find these graph for 4 ohm load on TPA2028D1 data sheet.
    -Ivan Salazar
