• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » Precision Amplifiers » Precision Amplifiers Forum » PGA309 Manually Generated Lookup Table?
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Grounding Principles
    Posted 4 days ago
    by Bruce Trump
    In a previous blog on supply bypassing , I cautioned that poor...
    Handy Gadgets and Resistor Divider Calculations
    Posted 12 days ago
    by Bruce Trump
    Handy gadgets make our engineering life easier—the little...
    Chopper Op Amps—are they really noisy?
    Posted 19 days ago
    by Bruce Trump
    Chopper op amps offer very low offset voltage and dramatically...
This question is answered
Andrew Meier
Posted by Andrew Meier
on Mar 13 2012 12:42 PM
Prodigy70 points
The PGA309 Calibration Spreadsheet is an efficient way to use three sensor voltage output measurements at three temperatures to generate a lookup table that adjusts the zero and gain DACs with temperature.
My question is, does it ever make sense to bypass the Calibration Spreadsheet and manually generate the lookup table?  For example, in correcting not only the sensor response, but also the system that the sensor is measuring?
PGA309 LUT lookup table calibration spreadsheet
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Ian Williams
    Posted by Ian Williams
    on Mar 13 2012 17:42 PM
    Verified Answer
    Verified by Ian Williams
    Genius14235 points
    Hi Andrew,
    The lookup table is typically stored on an external EEPROM or in the memory of a microcontroller/microprocessor. It is not a static table - throughout the calibration process new values are written based on the measured sensor input voltages and the calibration calculations that are performed. There are variations on sensors from the same family (even the same part number!) which require different sets of coefficients to be stored in the lookup table. My manager likes to use the analogy that sensors are like snowflakes; no two sensors are alike.
    For proper calibrated operation the lookup table should not be bypassed. I'm not sure I understand your question about correcting not only the sensor response, but also the system that the sensor is measuring. The input to the sensor is a real-world value, for example, 100 psi. That 100 psi at the input is actually 100 psi, not 97 psi. However, in theory, if any errors in the system at the input to the sensor resulted in error voltages at the output of the sensor, they could be calibrated out.
    Ian Williams
    Linear Applications Engineer
    Precision Analog and Sensing Products
    Calibration PGA309
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
