Please answer following question from customer.
Datasheet page 4 “FUNCTIONAL BLOCK DIAGRAM” has “Short Circuit Detect” function.
Please advise how to detect short circuit and its threshold.
Best Regards.
Best Regards.
Hello Karl-san,
Please ask application engineer to answer my question again.
Best Regards.
Hello Clancy-san,
Please answer my question I posted on Nov 17, 2015.
Best Regards.
Hello Clancy-san,
Short circuit current limit is not specified so I have to at least report the current while ”the power and load ratings in the datasheet” to customer.
Best Regards.
Toshio,
The minimum load ratings give good insight into the current limitations. The -Q1 datasheet doesn't have these listed, but the catalog version of the datasheet does (it was more recently updated):
It is also important to consider the RDS_on of the outputs FETs:
During a short circuit condition, you can calculate the current using:
I = V/R
I = V/(RDS_ON*2 + R_other)
At 3.6V, the short circuit current is about 3A. At 5.5V, the short circuit current is about 5.5A.
With a load, the peak current is much less than this. According to the tables, the peak current will occur at around 4.2V with a 3.2 ohm load, which gives a peak current of about:
I = (4.2V/(2*500mOhms + 3.2 ohms + R_other)
I = 1A
Hello Clancy-san,
Thank you for your answer.
Could you please post complete answer including image of datasheet that you posted Nov 30th to understand accurately.
Best Regards.
