I confirmed that noise was generated when changing "Output Routing" setting with "Codec Control".
For example, click on the red circle in the figure below.
I confirmed that noise was generated from the speaker L and headphones L connected to the evaluation board.
Is this a problem with the configuration procedure?
If yes, please tell me the correct setup procedure. If no, please tell me what are the possible causes.
Thank you!
