Other Parts Discussed in Thread: PUREPATHSTUDIO
I apply software:PUREPATHSTUDIO. (setup_PurePath_Studio_Portable_Audio_MiniDSP_v5.95_build1_rev35815)
but show up the issue:Error reading setup initialization file, how to solve it.
thanks.
thanks.
Hi, Wu,
Can you please try downloading the installer for PurePath Studio with a different network?.
This issue has been reported before, typically a network issue during the download of the installer may cause issues to the file.
-Diego Meléndez López
Audio Applications Engineer
Can you please provide a capture of the error you are getting?. In some occasions, the installer needs to run with administrator rights and in compatibility mode. Have you tried this?
Thanks for the additional information. If running the software as admin in compatibility mode doesn't work, It is likely that the file is corrupt. I can share a working version of PPS, please send me your email address on a private e2e message.
HI,
I'm having the same "Error reading setup initialization file" even after downloading the file on a stable network and running it as admin in compatibility mode. Could you share another download link ?
I can send you an email address via private message.
Quentin Hameau
I have sent you the link for the PPS installer I have used before. Please download it and check if it works.
I had no problem with the installer this time, it works great, thank you Diego !
Quentin Hameau
Hi, Atan,
I sent you the download Link via email, It is not possible to send it through e2e message, I asked for the connection so you can share your contact information.
