Hi James,
That is called a ground loop.
It is most likely that the audio source of TPA6120A2 has a different ground reference.
You can take a look at this App Note about Ground Loop Break circuits, it mentions TPA613x and DRV60x but apply to this device as well: http://www.ti.com/lit/an/sloa143/sloa143.pdf
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
James,
That still sounds like a ground loop, it is not at the amp, but at your supply.
Your short from AC to DC side on the SMPS would be the Ground Loop Break.
One thing I can think of is about your input signal to the amp. Are you using single-ended or differential input? It would be best to use differential, perhaps it can reduce the impact of this noise, if it's coming along with the input signal.
Are you able to inspect the signals along the path? You could be able to identify where is the noise source.
Other way to try this is to disconnect the amp from the input and check if the noise is still present; if the noise is present even when the input is not connected then the noise would be coming from the supply/GND, in that case you can try to identify the frequency and apply filtering at the supply input to the amp.
-Ivan Salazar
James,
I mean disconnect the headphone amp from its input.
What I try to know is if the noise is coming from previous stage, or its due to supply/GND coupling noise.
You could try floating or grounded inputs as well.
-Ivan Salazar
James,
It is good to know that you've narrowed down the source of the noise in your system.
Please let us know if you have any further questions about our devices.
-Ivan Salazar
