Help for Choosing the Right Audio Codec !!!
Hi All,
My name is Canan Simsek. I am doing my bachelor thessis in TI Germany on the topic of "Clock Jitter Influence on Audio Quality ".  I want to measure the effect of the CDCMP312 ( Clock generator ) on one of the audio codec which has Sigma Delta architecture in it. For this implementation, I need an EVM board and I have choosen 3 audio DAC from TI products  - Data converters - Audio converter - Audio Dac http://www.ti.com/product/pcm1742  "PCM1742",http://www.ti.com/product/pcm1748 "PCM1748" and http://www.ti.com/product/pcm1753 "PCM1753". In my project Sigma delta converter is 4th order, My bandwidth is 2HZ - 20Khz and Sampling  Fs = 3.84 Mhz and OSR = 96Khz.
I need to know which EVM board can be useful for my measurements. Furthermore, with results of my measurements I want to measure INL - DNL for quality . How can I measure them from scope results ? Is there any special euipment to measure them ?
Thanks  and Regards
Canan simsek.
c-simsek@ti.com
1 Reply
  • Canan,
    Unfortunately none of these EVMs are currently available in the TI e-Store, so I would try to find a DAC EVM that is available.  For linearity, the level linearity spec of +/-0.5dB is the only linearity spec offered, but the randomization of noise within the DAC ensures the INL/DNL will not exceed this or cause performance issues as well.  We do not have any special equipment to measure INL/DNL, some folks use LabVIEW tests for INL/DNL tests but they require data acquisition hardware as well.
    Patrick Galvin
