We're using the TLV320AIC34 codec in single ended input mode. The datasheet specifies the absolute maximum rating for single ended inputs to be 0.707Vrms. What I'm trying to figure out is what the full scale voltage range is for the input and what this range would correspond to in values read from the Codec. My assumption is the voltage input signal can go from 0v to 2v where 0v would correspond to a 16bit reading of 0x0000 and 2v would be 0x7FFF. Please let me know if this is correct. If not, what is the actual voltage input range and corresponding readings?
