I received a PCM5242EVM today; it arrived with NO documentation. Going to the TI website for the EVM, I find the Technical Documents tab does not respond. I found only a quick-start guide for a board with a headphone amp. My EVM has no HP amp, only XLR outputs.
The board has what appears to be a USB micro B connector. Is that correct? Had I known one was required (there is no mention on the TI website, nor is one supplied) it could have saved me a week.
The board also has Toslink and SPDIF connectors. The Toslink is at least marked as an input, but the SPDIF is not marked. One assumes it is an input because there is a jumper below which allows MCLK to come from either SPDIF or USB. Will the board run standalone using these other inputs? or does it have to be configured using a PC? How about playing iTunes from a Mac?
Eventually I want to feed the DAC I2S signals, so thorough technical documentation would be appreciated.
