the PCM1792A data sheet doesn't go into any detail about how exactly the output attenuation (volume control) works exactly as far as its signal processing functionality (the control aspect is well documented). So I need some additional information from someone at TI.
- where in the signal chain (e.g. the functional block diagram) is the attenuator?
- is it analog or digital (obviously, it's digitally controlled)
- if it's digital, what impact on the signal resolution does it have? (e.g. is there extended resolution math, truncation, etc.)
Look forward to some details!
Marc
