I'd like to use the PCM1864 (4 channel audio ADC) for our next design, but I have a question about the inputs. I want to DC-couple the inputs, because I want to extend the bandwidth to less than 1Hz in the lower end, and to avoid the >10uF coupling capacitors.
The datasheet doesn't specify the common mode voltage at the inputs. Is it at AVDD/2? Does the VREF pin give access to this bias voltage?
Thank you very much in advance.
Diego.
