• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » /etc... Data Converters » /etc... Data Converters Forum » ADC and DAC for TMDSDSK6713
Share
  • Forum
Options
  • Subscribe via RSS
This question is answered
Nicholas Schwarz
Posted by Nicholas Schwarz
on Mar 09 2011 13:07 PM
Prodigy20 points
I'm new to TI's line of DSP products and was hoping I could find some advice here. I'm prototyping a low latency device for a biological application. The device needs to input two analog voltage channels via an ADC, do some processing that involves using the input voltage as the input variable to a simple equation, and then output the value as a voltage via a DAC channel. Each pair would be independent, i.e. AI1 is the input used for AO1, and AI2 is used for A02. The application needs 16-bit resolution on the ADCs and DACs at 20kHz per channel. It would be nice to have a +/- 10V input range, but I can condition the input to be smaller, say +/- 1V or +/- 2V. The specifications mentioned are the minimum requirements, so there would be nothing wrong with a higher sample rate or resolution, or more channels.
The TMS320C6713 DSP Starter Kit seems like a good place to start, however, it doesn't integrate the ADC and DAC component that the application requires. Next Dimension Technology's AD6M daughter card is almost what I would need, I think, but it's only 12-bit. From some of the other posts TI makes something called the 5-6K Interface Evaluation Module as well as a number of other ADC and DAC evaluation modules. I apologize for my ignorance about your product line: when using the evaluation modules (EVMs) do I need to purchase both the EVM and the appropriate ADC/DAC chip or is the chip included with the EVM? Can you provide some more information about the daughter card as well as a recommendation for ADC and DAC modules I would need to assemble a working prototype?
Thanks very much,
Nicholas
DSK6713 DAC 5-6k interface ADC
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tom Hendrick
    Posted by Tom Hendrick
    on Mar 15 2011 08:31 AM
    Verified Answer
    Verified by Tom Hendrick
    Guru86210 points
    Hi Nicholas,
    I don't think we'll have anything 'off the shelf' to give you exactly what you are looking for.  The 5-6K Interface board is basically a carrier board that breaks out the two 80-pin daughter card connectors found on the TMS320C6713 DSK.  The card breaks out the two available McBSP ports from the DSP onto two serial interface headers giving you the ability to run independent ADC and DAC channels as you describe above.  It also breaks out the EMIF, which is how the AD6M card operates - that board uses the same connectors as the 5-6K Interface board.
    For the ADC side of your project, you could look at a few of our multi channel 16-bit ADC EVM's, perhaps the ADS8344 or the ADS8361 - these both have EVMs available and those EVMs will plug onto the 5-6K Interface Board.  The input range on these parts is 0-5V though.  To get you to the +/-10V input range on these devices, you could use the INA159 as the input signal conditioning front end.   The INA159 runs from a single +5V supply and does the necessary gain reduction/level shifting that would be required for these ADC options.
    For the DAC side of things, take a look at the DAC8564 or DAC8565.  Both of these devices also have EVMs which would plug into the 5-6K Interface Board as well.  The evaluation boards all come with the necessary components to get you up and running.  If you wanted to order sample chips as well, and have them standing by in case anything gets damaged during debug, you are welcome to do so.
    Tom
    Report Abuse
    • Reply
  • Anjana Govil
    Posted by Anjana Govil
    on Mar 28 2011 16:54 PM
    Intellectual815 points
    Hi Nicholas,
    I am the PME for precision DACs and Tom forwarded this email to me. Apart from the parts Tom mentioned, I will also recommend that you have a look at the DAC8562 - It is the new 16 bit, dual DAC that has a very good integrated reference in a small 3x3 package. From your description, it sounds that this part may be a great fit for the needs of your application.
    We do have final samples, EVMs available for this part and it will RTM in June 2011. Shoot me a note in case you need the pre-RTM samples or any support with any of the precision DACs.
    Anjana
    DAC8562
    Report Abuse
    • Reply
  • Nicholas Schwarz
    on Apr 01 2011 12:21 PM
    Prodigy20 points
    Hi Tom and Anjana,
    Thanks very much for your assistance and recommendations. Parts are being ordered. I'll post an update when I have more to report.
    Thanks again,
    Nicholas
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
