HI,
I would like to comfirm about SerDes line.
Customer is considering whether real data could be used for QAM signal created by FPGA.
Could they use real data, not complex IQ ?
Kato
HI,
Kato
Hi Kato,
Yes, they can send real data. The NCO and complex mixer cannot be used in this case, so they will need to send the data at their desired IF.
Matt Guibord
Hi Matt - san,
Thank you for the reply. I understood customer should use IQ data in their system.
*customer system
input->Zero IF(bandwidth=56MHz,QAM)
output->844MHz,bandwidth=56MHz
Would you give us the reason frequency by using real data couldn't be shifted ?
Kato
Hi Kato,
Real data cannot make use of negative frequencies so you cannot have a ZIF system. However, QAM by definition is complex data... so I'm confused about what's being asked here. They can generate a QAM signal at ZIF and mix it up to some IF (real IF) in their FPGA and then send this new signal to the DAC. In this case they are sending real data (which is fine) but the complex mixer cannot be used because it will generate an image sitting at a frequency of NCO - IF. Or they can send the ZIF data (I/Q data) to the DAC and they can use the NCO to mix the signal from ZIF to 844 MHz. This is the usual use case.
Matt Guibord
Hi Matt - san,
Thank you for the reply. Would you give us more detail about an image sitting at a frequency of NCO - IF ?
Customer would like to know why real data couldn't be used for the complex mixer.
Kato
