• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Data Converters » Precision Data Converters » Precision Data Converters Forum » ADS1291
Share
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
The Signal blog
  • $core_v2_blog.Current.Name
    Pop Quiz!
    Posted 2 days ago
    by Bruce Trump
    Put away your books and take out a sheet of paper. Each question...
    Settling Time
    Posted 8 days ago
    by Bruce Trump
    Settling time is the time required for an op amp to respond to...
    Slew Rate—the op amp speed limit
    Posted 15 days ago
    by Bruce Trump
    Slewing behavior of op amps is often misunderstood. It’s...
ADS1291
ADS1291
This question is answered
david sun77114
Posted by david sun77114
on Jul 09 2012 01:20 AM
Intellectual810 points
I wonder if the ADS1291 is a released product. in the data sheet I couldn't find a note tell me which channel to use because 1292 has two channels. I guess only one of the two differential input channel will work in 1291, is it IN1P and IN1N? I feel frustrated when I read the datasheet and slau384.  did I miss the description of 1291 or the document forgot to put it in.
David
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tony Calabria
    Posted by Tony Calabria
    on Jul 09 2012 07:46 AM
    Verified Answer
    Verified by Tony Calabria
    Mastermind42820 points
    Hi David,
    Yes, it is a released product and channel 1 is what you would use for the ADS1291. Channel 2 becomes a no connect.
    Tony Calabria
    Report Abuse
    • Reply
  • Fazıl Duman
    Posted by Fazıl Duman
    on Jul 30 2012 16:42 PM
    Prodigy125 points
    Hello ,
    I have some questions about ADS1291 which i could not find the answers on datasheet.
    1)IN2N, IN2P, PGA2N,PGA2P,RESP_MODN,RESP_MODP
    Are these pins not connected or connected to some where?
    2)Are we going to use same register table with ADS1292. Is there also 12 byte register table?
    3)  05h CH2SET is exist but are we going to dont care?
    Fazıl
    Report Abuse
    • Reply
  • Tony Calabria
    on Jul 30 2012 21:36 PM
    Verified Answer
    Verified by Tom Hendrick
    Hi Fazil,
    I understand the confusion, below are your answers -
    1. These are no connects and should be pulled high through weak pull up resistors.
    2. The register table does not change from the ADS1292 to the ADS1291. Register address 05h becomes dont cares but does still exist.
    3. See answer for number 2.
    Tony Calabria
    Report Abuse
    • Reply
  • Fazıl Duman
    on Jul 31 2012 03:22 AM
    Prodigy125 points
    Thank you Tony
    Report Abuse
    • Reply
  • HECTOR
    Posted by HECTOR
    on Aug 08 2012 07:59 AM
    Intellectual555 points
    Hello Fazl ;
    I am trying to use ADS1292 too ; could you share a working shematic please ; I have built a shematic but i am still need support.
    Thank you inadvanced
    Hector
    Report Abuse
    • Reply
  • Fazıl Duman
    on Aug 08 2012 09:59 AM
    Prodigy125 points
    Hello Hector,
    i have used same schematics from ADS129X ECG Frontend Development board.
    In shematics i used ADS1291, but also if you use frontends shematic (from datasheet) it will work perfectly.
    If you send your own schematic we can discuss it.
    Best Regards
    Fazıl
    Report Abuse
    • Reply
  • HECTOR
    Posted by HECTOR
    on Aug 09 2012 05:34 AM
    Thank you fazl ;
    I will send you the shematic on friday ; I am out of the office travelling to UK; infact I am good digital one ; but not analog one :) .
    Do you have good experience with ECG analysis ?
    By the way your name sound Spanish ; are you ? I am spanish too .
    Hector
    Report Abuse
    • Reply
  • david sun77114
    on Aug 26 2012 01:57 AM
    Hi, Fazil
    I notice in your schematic you have a low pass filter with 66K cut off frequency. and in slau384, it also use a 66K cut off low pass filter, do you know why use a 66K cut off low pass.
    and I notice there is a 100K resistor between pin 29 to pin30 in slau384 for drive out feedback. do you use drive out in your design? if not, is R1 and C2 necessary?
    thank you for share your schematic.
    David
    Report Abuse
    • Reply
  • Fazıl Duman
    on Aug 26 2012 04:50 AM
    Verified Answer
    Verified by david sun77114
    Prodigy125 points
    Hello David,
    This was my old schematics, now i changed some parts.
    66 kHz is only for reducing for unwanted noises, you can decrease the freq cutoff point to 2kHz levels by just changing the RC values, bu if you want to detect pacemaker activity do not set the value less than 20K Hz. I tried some R C combinations and get this result for ECG measurement.
    I place R1 and C2 for my other testings. I connected the 2 leads to PIN29 and PIN28 with 10M resistor and checked if baseline stability increases. (some small change with battery power supply)
     My primary applications is measuring ECG without a RLD. I noticed that if you want to get good ECG signal do not place extra components to ADS12xx but necessary components. Every extra component gives you a bigger noise than you expected.
    Fazil
    Report Abuse
    • Reply
  • david sun77114
    on Aug 27 2012 10:44 AM
    Hi Fazil
    I know many portable or handheld device don't use RLD. if you don't have limitation of the application, do you think RLD will improve overall performance? ( baseline stability as you mentioned)
    Thank you
    David
    Report Abuse
    • Reply
  • Fazıl Duman
    on Aug 27 2012 16:45 PM
    Verified Answer
    Prodigy125 points
    Hello David,
    RLD is very useful in many ways. If you dont have any limitations you have to use RLD in biopotantials measurements.
    For further reading i suggest you to check out this application note.
    SBAA188
    Fazıl
    Report Abuse
    • Reply
  • david sun77114
    on Aug 27 2012 17:17 PM
    Verified Answer
    thank you very much.
    Report Abuse
    • Reply
  • david sun77114
    on Sep 05 2012 00:54 AM
    Hi Fazil
    I have one more question, in SLAU384, there are 3 Ferrite Beads used for VCC.  L3, L4 and L7 all used 0603 package Max current is 2A. for current in mA circuit is it really necessary to use that big margin. I hope I can use 0402 package which is 500mA rated.
    thank you,
    David
    Report Abuse
    • Reply
  • david sun77114
    on Sep 13 2012 17:46 PM
    I have one question about 1291 layout. there is no recommended land pattern pqfp32 in datasheet. in 1292 website there is an allegro package symbol, but my 16.2 dbdoctor couldn't upgrade it. I am not a professional layout guy. could anyone send a link or post an allegro 16.2 PCB editor symbol. appreciate your help.
    David
    Report Abuse
    • Reply
  • Bo Nystedt102116
    Posted by Bo Nystedt102116
    on Oct 16 2012 10:20 AM
    Prodigy220 points
    Hello Tony Calabria, Fazil Duman, and Yuan-Heng Lu!
    I have followed this thread and the one where Lu shows his schematics, in my attempt to create a single-lead battery-driven low-energy ECG with rudimentary “patient-protection” based on ADS1291 and MSP430  micro controller. I would really appreciate if you, Tony, and anyone else would comment upon the schematic below. Will it work? What have I done wrong? What could be done better? I'm not an engineer by profession. I'm a surgeon but very interested in embedded design.
    As you can see I have left IN3N and IN3P unconnected. Can I use them for leads-on/off control? If they can be used for that purpose I would appreciate to get some directions about how to accomplish that.
    Further I want to kindly ask you, Fazil, to present your schematics in an other format. I have used .gif to present my schematics and I hope it will be easy to read. I have problems to read your schematics concerning your battery solution, which I find very interesting for my development. Thank you! Or  perhaps you can direct me to your source if you haven't developed them yourself.
    Regards Bo
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
